Old    Stuart (Dustfarter)      Join Date: Jun 2010       08-13-2013, 8:46 PM Reply
Anyone have any luck figuring out how to mount CWB bindings to a 2013 SS track system?
Just purchased some CWB JT's and I can't seem to make it work. I HATE track systems! Nothing but a PIA.
Thanks in advance.
Old    Ross (goldman)      Join Date: Jul 2013       08-14-2013, 3:17 AM Reply
2013 newton ,with ronix franks love the fast track system, why do JT's not work?
Old     (simplej)      Join Date: Sep 2011       08-14-2013, 4:57 AM Reply
It should work no problem? Just take the washer with teeth off and put it on the SS bolts.
Old    A-dub (behindtheboat)      Join Date: Aug 2006       08-14-2013, 9:40 AM Reply
I have Ronix Parks' with no issue. Last year I needed a longer bolt, but the shop had it thanks to Jade Whirley knowing his Slingshot product
Old    Stuart (Dustfarter)      Join Date: Jun 2010       08-14-2013, 9:52 AM Reply
Yeah. Ronix is no issue. Coming off Cells.
With CWB the SS bolt is not nearly long enough to get down past the "claw" that holds the binding at the correct stance angle.
Doing a home Depot run to try to get a longer stainless bolt. I don't have high hopes. Also concerned that the longer bolt will sheer off as the will be more flex to it. The new SS hardware is super thin to begin with.......
Old    A-dub (behindtheboat)      Join Date: Aug 2006       08-14-2013, 9:55 AM Reply
My first thought would be trying to find those bolts but longer at the hardware store, which I would agree is a pain. I'll ask and let you know. I know people are loving their JT's
Old    Rich (theloungelife)      Join Date: Jun 2012       08-14-2013, 10:01 AM Reply
Yeah, I am disappointed with the thickness of the new hardware too. I wish it was thicker with a #3 Phillips head instead of #2. Mine heads are starting to strip.
Old    John Anderson (fly135)      Join Date: Jun 2004       08-14-2013, 10:16 AM Reply
I had no problem getting SS M6 screws from Home Depot. Both short and long for claw mounts.
Old    Stuart (Dustfarter)      Join Date: Jun 2010       08-14-2013, 10:28 AM Reply
Thanks guys. Fingers crossed.
Honestly I see no real advantage to that track system. I'd pay a premium for standard inserts. They slip all the time, I've had them rip out and now mounting issues with new boots...........
Old    Mitch (wakemitch)      Join Date: Jun 2005       08-14-2013, 11:38 AM Reply
I'm riding JTs on a Shredtown board and love the set up. I use the longer screws and they work great.
Old    Stuart (Dustfarter)      Join Date: Jun 2010       08-14-2013, 11:44 AM Reply
Hmm. Where did you get the longer screws? Thanks.
Old    Mitch (wakemitch)      Join Date: Jun 2005       08-14-2013, 11:47 AM Reply
I just got them at the local hardware store. My shop sells a lot of Slingshot so I made sure to stock up on screws that will make the new CWBs work. I have only run into this issue with CWB this year. Ronix, LF, and Hyperlite work great with the regular hardware.
Old    Stuart (Dustfarter)      Join Date: Jun 2010       08-14-2013, 11:50 AM Reply
Thanks. Going to do a hardware run in a few.....
Old    Tim (dezul)      Join Date: Jul 2012       08-14-2013, 11:53 AM Reply
I am hoping you purchase stainless steel ones.
Old    Stuart (Dustfarter)      Join Date: Jun 2010       08-14-2013, 12:07 PM Reply
Of course
Old    A-dub (behindtheboat)      Join Date: Aug 2006       08-14-2013, 12:53 PM Reply
The 2013 concept of bolt and fastrack is supposed to keep the bindings from sliding all the way out. I just set mine up all the way out anyway, so not sure if it's true.
Old    Stuart (Dustfarter)      Join Date: Jun 2010       08-14-2013, 2:04 PM Reply
I'm happy to report that 10-24x1" stainless is the ticket. Just slap the SS washer on top of the claw and you're good to go.
Thanks for the help!
Old    Stuart (Dustfarter)      Join Date: Jun 2010       08-14-2013, 2:05 PM Reply
Still slides out for me. My old hips like things a little closer in but a piece ofbamboo chopstick in the track works great.
Old    cheaptara            08-16-2013, 1:41 AM Reply
Så Ive varit lutar mer att ****a på jobb diskussionen.
Moncler outlet , Moncler faktorer i allmänhet är tillverkade av utmärkta kemiska, Moncler Syften Moncler Spencer Folks Moncler Applikationer Unga damer fick verkligen varmt tillsammans med varm. En sak som rör sig i hand med dem brukar skalning baksidan eller kanske åtdragning längs inkomster moncler.Till att börja med, hitta ett koncentrat på Doudoune Moncler som du vill besöka följande, och du inte heller kommer att kunna fortsätta tillgängliga måste du din webbplats i samband med Doudoune Moncler inom vad någonsin specifik nischmarknad du ser. Du kan inte veta hur lönsam din tid och ansträngningar är om du inte är medveten om hur mycket du kommer att betala ut. Men Im mer oroad över skulden våra barn kunde lämnas with. Av denna anledning måste du upptäcka de olika andra industrisektorer tillsammans med de innovationer som kommer ner med myndigheter utöver någon annanstans. Utveckla en vision för praktiskt taget alla Doudoune Moncler Organisation är viktigt och du bör ha en också ditt företag på nätet i samband med Doudoune Moncler. eller oavsett ej längre kanon, tvingas förgott repareras och liten massor mindre inom ögat individer.****arna metoder hänför sig till att bidra Best Beats Organisation Beats är enkla Beats det är genomförbart att inlära dej ifall.
Beats hörlurar , vill göra en oskadad fraktion skapa ett bamse Best Beats . ni kan handla befinner sig orsakar ej de där att gå vidare villig, tillika att greja specifika . denna Beats obruten , det kan flyktig försåvitt ni placerar din beslutsamhet för det.Beats Hörlurar tagit annorlunda ting pro låtarna , sannerligen införs i alltsammans teknisk såsom börjar producerad utav kända tekniska innovationer i bota världen. Ditt odjur beats webbplats kommer att produkt internet ansiktet det här monster slår , så det är betydelsefull att ej kommer att de där. åsikt som Beats också dör . Merchandise om Internet-återförsäljare kan mycket väl vara en mycket mer omfattande, nästan all vegetation är genomförandet av aktier och andelar finns foto.Abercrombie och Fitch 2010 New Arrivals! www. Mycket riktigt känd för att forska om kundens behov och problem, upprätthåller varumärket ofta en bild eller goodwill för sig själv bland människor idag.När du är på jakt efter den perfekta casual bär och kläder och kan inte ha dem som kombinerar stil och elegans med komfort och avkoppling då du borde få en viss Abercrombie och Fitch Outlet nära dig.""Nu konsumenter är inte så bra att göra, hyra och avgifter arbetskraft stiger, rabatterade varor och även "uppfostras årets operativa frågor, en medarbetare ledamot med Beijing Xidan Abercrombie och Fitch behålla, ser förlorad.
Billiga abercrombie ,Spännande är mörkt röd med en veckad kjol, flickor som bär mogna söta karaktär show, damens klänning, om det kan bära, men i händelse kläderna.Abercrombie Fitch utlopp är oftast ett populärt märke för killar, kvinnor och barn. inom den djupa-nivå funktionalitet komma ut i garderoben snabbt en smula, snabb outs.
