Old    Scott (scotthons)      Join Date: Mar 2010       08-12-2013, 12:57 PM Reply
So I thought my front drain pump (Tsunami) went out so I replaced it this weekend. Still nothing. The switch lights up when turned on, but still no power to the pump. I ran the pump wire to the battery to get it working.
I really do not know where to go from here. I am not the handiest, but would like to fix this myself.
The boat is an '06 Supra 21V.
Thanks in advance.
Old    Russ Constable (Midnightv10)      Join Date: Feb 2012       08-12-2013, 1:16 PM Reply
So when you ran the pump wire to the battery did it work then?
If so, take a test light and test the wire starting at the switch.. and work your way towards the pump.. there may be a splice somewhere in the line that is loose or corroded..
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       08-12-2013, 2:34 PM Reply
There is a fuse panel under the dash that could have a blown fuse. I popped a couple of them on my rear drain pump. Lay in you back and look right behind the steering wheel. You see it labeled front drain pump.
