Old    Jason (Hooya)      Join Date: Aug 2011       08-07-2013, 12:51 PM Reply
Just wondering if anyone had a simple list of tricks by order of which to learn.
I am guessing it would start something like
Kicker -Basic heelside jump
Kicker -Switch heelside 180
How would you progress. Thinking first 10 or so tricks so you can do something on kicker/rail/air.
Old    Orion (chillinoj)      Join Date: May 2009       08-07-2013, 2:38 PM Reply
I'll give this a shot. I ride regular footed and a clockwise cable so some tricks are easier to land switch i.e. roll to re
Kicker: (assuming you have a TS and HS kicker to use)
-HS & TS Straight Airs with Nose, Tail, Indy, Method grabs
-Switch TS & HS of above grabs
-HS & TS fs180 - Add grabs and tweaks for style
-HS Backroll
-Switch Scarecrow
-Switch Backroll to Revert
-HS Raley
-HS & TS fs 360
-HS & TS bs 180
Air Tricks
-Air Roll
-Air Roll to Re
-Air Raley
-Air Krypt
-S Bend or Front Roll (similar motion, usually one is easier for you to do correctly)
-Roll Mobe? dunno getting above my level for airtricks now
Rails Wil really depend on what types of rails the park has
-FS Board
-BS Board
-Nose Press
-Tail Press
-Transfers or wallrides if available
-Try ollie-ing up to different parts of rails for new lines.
Old    Jason (Hooya)      Join Date: Aug 2011       08-08-2013, 4:13 AM Reply
Excellent work. Exactly what I was after.
Old    Brad S (wakeskierbrad)      Join Date: Dec 2009       08-16-2013, 1:42 PM Reply
Above is good, but would like to add, don't skip the HS and TS airs with proper grabs, nose and tail, and between the boot grabs.
