Old     (silverlude)      Join Date: Apr 2004       08-07-2013, 10:22 AM Reply
Can't find any epoxy repair nearby for needed nose repair of IS Swallow board. Would it be ok to use JB Weld? I have regular fiberglass resin but it always seems to just chip away and have to do it over again. Need it for Friday as the board was dropped on tip and now chipped and cracked again. Ordering a epoxy kit will take too long to get here so need something I can find at hardware store. Thanks
Old     (Chaos)      Join Date: Apr 2010       08-07-2013, 12:08 PM Reply
Brian, sand with 80 to 100 grit paper, and then clean the area with ethanol or isopropyl alcohol. Get a two part clear kit at the hard wear store, slower is better.... the 30 minute type will yellow less than a 5 minute cure epoxy. Your inland is epoxy laminated, but usually has paint on the surface with a clear coat or gloss.
Nick
