Old    kx250frider617            07-28-2013, 1:04 AM Reply
So I recently re-packed all the bearings with grease on my trailer. I towed it for 10 miles and felt the rear axle w/ brakes and the hubs were pretty hot. The brake axle both had hot hubs and the other was fine. I really don't think its a bearing issue but a brake issue. I think the brakes are dragging. The trailer is a 2001 Extreme for a tige 21ft, dual axle, leaf springs, bearing buddy.
What are the main causes for brakes sticking and how can I easily fix it? I only have 1 day to fix it then leaving for a lake trip. I will be towing with a F350 diesel so my last resort would be to disconnect the brakes. What is the best way to do that also?
Old     (WheelerWake)      Join Date: Mar 2013       07-28-2013, 5:26 AM Reply
I had the same problem. It was caused by the emergency break-away system in the hitch. It was sticking and would hold the brakes on.
Old    kx250frider617            07-29-2013, 12:59 AM Reply
Ended up being the brake pads, the pads separated and the material was getting wedged up against the rotor. I just removed the brakes altogether for now. The super duty shouldn't have a problem with a 21ft boat.
Old     (wakebordr11)      Join Date: May 2001       07-29-2013, 5:16 AM Reply
On our 2000 eagle trailer the brake cylinder seized up causing the pads to rub rub rub which would heat up the grease, the hubs would go dry and I cooked a bearing... scary time. Nothing bad happened luckily
