Old    Billy Boozer (bboozer)      Join Date: Apr 2007       07-19-2013, 8:51 PM Reply
How are Liquid Force bindings sized? I see that they overlap sizes,there are size 10-11and then 11-12..... I wear a size 11 in Nike shoes and have worn 11 bindings in other brands, so which size 11 should I go with in Liquid Force
Old    Adam Balon (adam_balon)      Join Date: Jul 2003       07-19-2013, 11:51 PM Reply
i wear 10's and ride the 10-11 watson and shane. i have had the watsons every year for the past 3 years. the fit is true.... they are amazing. you will have a little bit of stretch due to them getting wet...... but not alot. try a few pairs on at a shop. i would recommend the 11-12 most likely.
Old    Austin (austin)      Join Date: Apr 2010       07-20-2013, 7:20 AM Reply
There is no substitute for trying them on. If you can't find a shop that has them, maybe consider buying both from an online store that will let you return one pair after you can try them both on (usually you can only return if they haven't been in water yet).
Old    sperbet            07-20-2013, 1:34 PM Reply
I wear an 11 in most shoe sizes, occasionally an 11 1/2. I used to always be an advocate of sizing down and I rode a few pairs of LF 10-11s. I did have some serious toe stubbage problems and went with the 11-12 for my most recent pair. They do fit better, for me anyways. With that being said the binding are 2011 models and I'm not sure on the current specs. If you can, your best bet is to try them on. If not you'll probably be ok with either, but I'd go with the 11-12s.
Old    Ryan (ryanw209)      Join Date: Jan 2010       07-21-2013, 10:52 PM Reply
Go with the bigger size. I wear a 10.5 shoe and ride 11-12's but I don't like my toes touching at all.
Old    Bevan (stxr_racer)      Join Date: Jun 2006       07-22-2013, 5:57 AM Reply
I'm a shoe size 11 and wear 11-12 Watsons...perfect for me!
