Old     (jmanst15)      Join Date: Jun 2010       07-15-2013, 10:55 PM Reply
I am doing a slight stereo overhaul. Getting an XDI805 installed for my stock infinity in-boats and a new Arc KS12 sub. I have pro 60s up top. Which in boats should I go with that will work well with the XDI805???
Old    Paxdad            07-16-2013, 3:40 AM Reply
I just had the ARC Audio Xdi805 installed and used the Rockford Fosgate M262B and they work great. My Xdi is also running a WS 10" sub. I have the WS Pro485s on the tower running off an Arc 600.2. Everything is controlled through the WS 420 EQ/ Line driver.
Old     (chpthril)      Join Date: Oct 2007       07-16-2013, 4:55 PM Reply
The XDi805 will deliver 80W rms to a single 4 ohm speaker or 60W rms with a pair of 4 ohm speakers p/chnl wired in parallel. So, go with which ever marine 6.5" speaker you want. Go with the ones you like the looks of, sound of and price of, as they will all perform well on that amp.
The XDi will deliver 400W rms on the sub chnl, so be sure to get a 4 ohm DVC Arc 12.
Old     (jmanst15)      Join Date: Jun 2010       07-16-2013, 11:04 PM Reply
Would I be able to run 4 XS 650's? Or do I need to stick to the XS 65's if I go the wetsounds route?
Old     (chpthril)      Join Date: Oct 2007       07-17-2013, 6:03 AM Reply
You can 8 xs-650, if you wanted.
