Old     (gregs_place)      Join Date: Sep 2012       07-14-2013, 8:35 PM Reply
I am in the market for a cable wakeboard. I am currently deciding between the 2012 Ronix Phoenix and the 2012 CTRL Blueprint. Could anyone give me some insight on these boards?
Old     (fly135)      Join Date: Jun 2004       07-15-2013, 9:43 AM Reply
I wore my CTRL RX down to the foam in only 3 months. Don't really recommend a non grind base for the cable unless they are cheap throwaway boards. CTRL has spouts some crap in their description that says they don't need a grind base. That's because once you bought it they don't need a grind base on your board, you do.
We donít use or need the typical grind or jib base. No 4 letter base materials here, you industry peeps know what Iím talking about. Instead, hell, why not just build boards that straight up perform and hold up to some abuse. Putting a band-aid bottom on a board so that the rail can fail or the board can break, what is the point? With Flak, our lowest end boards with a simpler base construction will hold up as well as these Grind or Jib Base boards and believe me we are just getting started on those.
Old     (mmahlie)      Join Date: Jul 2013       07-15-2013, 2:54 PM Reply
Slingshot shredtown is a great cable park board. The wood will not deteriorate or break under heavy riding conditions. Bart's water sports gave me the best price and I will not ride another board in the park or wake!
Old     (gregs_place)      Join Date: Sep 2012       07-15-2013, 3:06 PM Reply
Would Ronix boots work on a Slingshot board?
