Old    Jeremiah Long (machloosy)      Join Date: Mar 2013       07-08-2013, 5:18 AM Reply
I've got an '88 Ski Supreme(Supreme now) 20ft open bow. It has an Indmar 351 With a Holley 600 Marine on top. Boat and motor have 1173hrs. The heads/gaskets/plugs/carb are all NEW 2yrs ago. Anyhow, the current 4-blade won't spin past 3500rpms when the boat is loaded up(2k-2300lbs of people, gear, and ballast), and the 3-blade doesn't hold speed as well when I cut. Anybody have experience or suggestions?
Old    Spencer (spencerwm)      Join Date: Feb 2009       07-08-2013, 11:04 AM Reply
You should go with the Acme 543 prop and don't cut as hard. You will experience cavitation if you try to turn sharp with that much weight.
Old    Jeremiah Long (machloosy)      Join Date: Mar 2013       07-08-2013, 11:14 AM Reply
I don't power turn so it doesn't matter. Thanks for the advice, if someone has a used one, PM me.
