Old    CB (cassidyb)      Join Date: Feb 2012       06-30-2013, 8:52 PM Reply
So I ended up chewing my prop this weekend on a hidden shoal and I need a replacement. Boat is a 97 Prostar 205, live in denver (5000ft elevation), ford 351, power slot transmission, typically run around 2000+ lbs for boarding and surfing but also use the boat for slaloming so Id like to keep the top speed in the mid 30's. What prop should i get?
Old    J R (rasorjb)      Join Date: Nov 2011       06-30-2013, 9:42 PM Reply
If you send of an email to www.wakeprops.com they will be able to tell you exactly what you need!
Old    Spencer (spencerwm)      Join Date: Feb 2009       07-01-2013, 1:02 AM Reply
CB,
What are you running now, OJ 14x18? I think you could get some more low end without a huge reduction in top end by lowering the pitch. The elevation is a killer. Call WakeProps.
Old    Nick A (Therapy10)      Join Date: Oct 2011       07-01-2013, 5:21 AM Reply
I have a 97 205 but it is an indmar 350 1:1 and I like acme 543. Are you sure the specs are right? Ask on mc team talk if you don't get your answer here.
Old    Jack Henry (racer808)      Join Date: Jan 2013       07-01-2013, 6:02 AM Reply
CB, where did you hit something?
Old    Eric (DenverRider)      Join Date: Feb 2013       07-01-2013, 10:20 AM Reply
How bad is the old prop? The Prop Doctor in West Denver on Alameda (I think they recently renamed it to something else) repairs props as long as the damage doesn't extend too far to the center section of the prop where it gets thicker.
Old    Jack Henry (racer808)      Join Date: Jan 2013       07-01-2013, 10:50 AM Reply
Jims prop repair in Wheat Ridge fixes them up as well
Old    CB (cassidyb)      Join Date: Feb 2012       07-01-2013, 11:26 AM Reply
Current prop is an OJ 13x16....
I am sure the boat specs are right.
Hit something out at Navajo, we were taxiing about 100 yards off the shoreline in 45ft of water and out of nowhere the depth finder went to 3ft, have no idea what we hit. It mangled the prop pretty good tho, chewed it all the way from the base of the blade to the tip. No vibrations and no damage to the tracking fins or rudder tho.
Old    Chris Dirty (Dmac420sj)      Join Date: Mar 2012       07-01-2013, 11:47 AM Reply
Get your old one fixed and repitched if you want. Always nice to have a backup especially when camping
Old    Davidson Taylor (DavidsonTaylor)      Join Date: Jul 2013       07-02-2013, 12:17 AM Reply
You hit or something?
