Old    Hydrodynetahoe            06-28-2013, 1:41 PM Reply
So I'm leaving for Tahoe tommorrow and i need to know if when i get up there i need to do anything to make it run like it does when i use it at Lake Berryessa. The boat has the Black Scorpion engine.
Old     (shawndoggy)      Join Date: Nov 2009       06-28-2013, 2:12 PM Reply
a much much much lower pitched prop. Taking a boat from sea level to 6,000' is going to reduce horsepower by 30%. You need to make up for that by getting a prop with a lower pitch.
Old     (jbird)      Join Date: Jun 2011       06-28-2013, 4:34 PM Reply
Is there a bilge check at Tahoe?
Old     (lionel)      Join Date: Nov 2005       06-28-2013, 8:49 PM Reply
Is there? They will clean your boat like no other...
Old     (Dmac420sj)      Join Date: Mar 2012       06-28-2013, 8:52 PM Reply
Ya invasive species inspection. Don't be a GAYPER merit!
Old     (bstroop)      Join Date: Apr 2005       06-28-2013, 9:31 PM Reply
I take mine from 4500ft down to sea level all the time. Not enough performance loss for me to drop coin on a different prop.
Old     (Camsquared211)      Join Date: Jun 2013       06-29-2013, 12:23 AM Reply
Bring your wallet! The inspection costs more than what is fair. Also the Launch fees at Lake Tahoe are usually around $20.
When you get to Tahoe you will have to go to a certified station that will inspect, drain, and wash your boat. No ramp in Tahoe will let you launch without doing this.
I talked to the boat dealer when I bought my boat. They said if i plan on going to Tahoe with it, I should get a different prop.
Old     (Dmac420sj)      Join Date: Mar 2012       06-29-2013, 6:20 AM Reply
Your gonna be driving around doing a wheelie the whole day!"everybody get in the bow!!"
Old     (tommyg)      Join Date: Apr 2002       06-29-2013, 6:58 AM Reply
headed up there as well today. Definitely set aside some time for inspection. Takes over an hour with our Malibu as they fill and empty each ballas tank (4), one at a time. It's painful. Also will cost over $100 if you want in 'n out privelages for the year (a bit less for the week).
If you're loading the boat down, you may want to prop down, otherwise, just plan on taking a bit longer to plane. It's really not that big of a deal for us, but our only extra weight is the people we cram into our boat.
