Old    Mike (24vdhd)      Join Date: Aug 2010       06-25-2013, 11:16 AM Reply
I have an 04 tige 24v with pcm 330 with pcm trans 537 acme prop with 1250 ballast in rear drivers side locker
when surfing it feals like a trans slip but is only doing it in rough choppy water. i could not get it to do it in calm water yet
so would this be considered prop slip or cavitation?
Old    Hey, You scratched my anchor! (bftskir)      Join Date: Jan 2004       06-25-2013, 12:51 PM Reply
probably cavitation.
but- since you are leaning the boat over a low fluid condition could cause it to slip while it bounces around in the choppy water
check fluid level-keep full
Old    Charlie Zulu (Pad1Tai)      Join Date: Jan 2013       06-25-2013, 5:34 PM Reply
Sounds like cavitation but I run my motor and trans oil a tad over full because of the extreme angle of the engine when surfing..
Old    Mike (24vdhd)      Join Date: Aug 2010       06-26-2013, 9:53 AM Reply
cool thanks i am going out in a few hours i will check the fluid
