Old    Matt Crowe (crowem87)      Join Date: Nov 2005       06-24-2013, 8:30 AM Reply
Hey all,
Ran the boat out of gas and burnt up the fuel pump. I replaced it with an Airtex E2044 which is what i had seen other people online using. I believe it should be spec'd at a max of 100psi. I am worried that maybe the flow rate is not high enough? We replaced... ran the boat and I am only seeing about 50psi at the fuel rail and i am not getting fuel power out of the engine. Can someone please confirm what fuel pump should be in this thing? If that pump is correct what else could be causing this?
Thanks,
Matt
Old    Brett Yates (polarbill)      Join Date: Jun 2003       06-24-2013, 8:47 AM Reply
I can't confirm the fuel pump but I seem to remember people saying to be careful when replacing the actual pump within the module to not kink any of the fuel lines. Where you careful when replacing those lines?
Old    Mike (zimme)      Join Date: Feb 2013       06-24-2013, 8:53 AM Reply
Lots of info on the MC fuel pumps over on TeamTalk fyi
Old    William Burell (williamburell)      Join Date: Sep 2011       06-24-2013, 8:55 AM Reply
Agreed. Do a search+teamtalk. Tons of info online
Old    Matt Crowe (crowem87)      Join Date: Nov 2005       06-24-2013, 9:06 AM Reply
Ya I posted this on teamtalk as well - just going broad to get some answers... I believe the line is relatively straight and should not interrupt flow - I will check again tonight. Does anyone know if the fuel pressure regulator is adjsutable?
