Old     (raceman121)      Join Date: Nov 2012       07-25-2014, 11:28 AM Reply
the wet sound set up or sound pack three has two rev 410's and 6 wet sounds SW650's in boats it has one syn6 and one syn4 to power all of it.
i believe the syn4 is use just for the tower and the syn6 for the in boats.
So how underpowered is this system. and how would you set it up/change it to make it the best. weather it takes adding an amp or what
Old     (Jmorlan)      Join Date: May 2013       07-25-2014, 11:40 AM Reply
Would change to an sd4 for the towers
And sd6 for the in boats
The syn4 will give you 400 per 410
The sd4 will give you 585w per 410
Syn6 will give you 65w per in boat
Sd6 will give you 185w per in boat, use this conservatively.
But keep in mind also, those wattages are rated at 14.4v..
Old     (shawndoggy)      Join Date: Nov 2009       07-25-2014, 11:47 AM Reply
Keep Syn 4, but put it on the cabin speakers.
Replace Syn 6, replace with SD6, bridge to 3 channels: 585w per 410, 585w for sub.
Old     (Jmorlan)      Join Date: May 2013       07-25-2014, 11:50 AM Reply
^ or that if you don't have a large sub. Definitely more cost effective
