Old    Matthew Smith (LKASurfing)      Join Date: Nov 2011       06-21-2013, 7:20 AM Reply
Last week before The World Series stop in VA I was able to Surf with WakeSurfNC.com & Brian Baker!
We set up the bowl, It was so sweet to actually surf it!!!
Baker Catching some air on his Pro Model Soulcraft!
Old    James Harold (jdjjamesz)      Join Date: Mar 2008       06-21-2013, 7:25 AM Reply
nice..
Old    A.J. West (you_da_man)      Join Date: Sep 2009       06-21-2013, 9:52 AM Reply
What boat is making the goofy wake?
Old    Rayprisz (priszkid)      Join Date: Aug 2007       06-21-2013, 10:29 AM Reply
Dude- that's sweet! Looks like good times!!!
Old     (CarZin)      Join Date: Feb 2011       06-21-2013, 11:14 AM Reply
The goofy wave is an SV244. The regular is an SV233 (I believe). The SV244 was running stock ballast with an additional 500 pounds of lead. I believe 300 pounds were under the rear compartment bag, and then 200 was under the seats under the Pro ballast bag.
Old    Anthony T (v10rider)      Join Date: Oct 2012       06-21-2013, 11:47 AM Reply
Definitely want to try that. Looks like good times. By the way, how close were the boats side-by-side? 10ft?
Old    Matthew Smith (LKASurfing)      Join Date: Nov 2011       06-21-2013, 12:58 PM Reply
Carzin is correct on the boats the SV233 was stock -500lbs!!! (Actually found out my Quick fill wasn't working)
I'd say 10-12ft is about right on distance of the boats!
It is tricky to do and also tricky to ride in but I was able to go back & forth between the two pretty well! Cannot wait to do it again!
Old     (CarZin)      Join Date: Feb 2011       06-21-2013, 2:25 PM Reply
How did you figure out the quick fill?
Old    Matthew Smith (LKASurfing)      Join Date: Nov 2011       06-21-2013, 5:37 PM Reply
Just happen to put on the trailer with out emptying....threw the switches to empty...nothing port side...next day tried again with same result. could hear some water in tank when trailering through neighborhood. Opened manually with allen wrench....out came pink antifreeze!....Hadn't worked all season!
Old    A.J. West (you_da_man)      Join Date: Sep 2009       06-22-2013, 10:18 AM Reply
That 244 goofy wave looks so clean. Is it standard LH rotation or optional RH rotation for goofy riders?
Old     (CarZin)      Join Date: Feb 2011       06-22-2013, 6:25 PM Reply
It is right hand rotation.
