Old    S S (SurfTex)      Join Date: Mar 2012       06-01-2013, 12:57 PM Reply
I wanted to say a big thank you to Ragboy for his recommendations in getting our surf wake this dialed in. We primarily ride regular thus we are mainly focused on the port side. We have the pro-ballast setup and we swapped out the rear port bag for a custom Z3 ballast that holds just over 1300 lbs. With the port side front ballast full and port side rear ballast full, I will then fill the starboard front ballast to 75% and keep the rear stock ballast at around 50%. The weight or ballast percentage that you run on the starboard side is directly proportionate to where people are sitting and getting the boat to list to around 8%. I typically run taps at 3 and pull a little slower than 11mph but the speed depends quite a bit on the board you are riding and the weight of the rider. With this setup the wave has good push and there is about an 8-10' sweet spot.
Here is a picture of what the wave looks like with 3 people on the boat. Keep in mind the water was a bit choppy that day so the wave isn't quite a smooth as it normally is. For those of you with a Z3, I hope this post helps in your quest for the ultimate surf wave.
SurfTex
Old    TJ (Houstonshark)      Join Date: Jan 2011       06-01-2013, 1:10 PM Reply
That looks awesome! Do you have the Convex VX?
Old    S S (SurfTex)      Join Date: Mar 2012       06-01-2013, 7:21 PM Reply
No VX. I purchased my boat before it was an option. I have thought about adding one but the wake has been so good to date I haven't felt the need.
Old    Robert Garcia (ragboy)      Join Date: Aug 2007       06-01-2013, 8:46 PM Reply
Your welcome, and that is looking great. It is such a fun wake.
Old    Travis McCartney (93lxt)      Join Date: Dec 2011       06-02-2013, 5:52 PM Reply
Thanks for the post.
I just took delivery of my 2012 z3 and installed the convex vx last week and can't get any push with the surf ballast setup the boat came with.
I have the pro ballast bow bags coming from tige this week as well as aftermarket custom sacks for the port and starboard rear sides.
Any tips for setting up with the vx ?
Old    Robert Garcia (ragboy)      Join Date: Aug 2007       06-02-2013, 5:58 PM Reply
The VX makes an even nice transition, and it also smooths out the wake and keeps the wash off, but it also adds a bit of lift. We found that when we weighted without the VX, adding 3-400 lbs on the surf side seemed to fix that, compared to without.
Old    Mark (biggator)      Join Date: Jul 2010       06-03-2013, 3:16 PM Reply
Damn that looks good.. like you've got a stack of 9950s in the locker.
Old    Nate Arnold (natedogg)      Join Date: Aug 2011       06-03-2013, 4:15 PM Reply
SurfTex, is that Canyon Lake?
Old    S S (SurfTex)      Join Date: Mar 2012       06-03-2013, 4:48 PM Reply
Close natedogg, Lake Travis.
