Old    Chris (rio_sanger)      Join Date: Apr 2007       05-28-2013, 3:53 PM Reply
Hi all, it's been some time since I've posted on here, but could use some help diagnosing a new problem. '99 330hp Black Scorpion with 620 hrs. meticulously cared for and maintained. Has always run perfectly since new. This weekend, after starting up and idling a bit, went to pull up a rider and it stuttered and kind of "skips a beat" like it's running on 6 or 7 cylinders. At higher rpm, it is a bit smoother, but still a noticeable misfire and roughness. Pulled some plugs and they looked fine, I had replaced them at 500 hrs. Feels like it might be an injector(s)? Put some injector cleaner in gas and changed fuel filter, but no help. Any ideas? I keep the boat at the river 4 hrs from home so I'd like to try and fix it there and not have to tow it back to a mechanic. Thanks in advance for any advice!
Old    Lionel (lionel)      Join Date: Nov 2005       05-28-2013, 4:10 PM Reply
Fuel filters, cap/rotor, plug wires.
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       05-28-2013, 4:10 PM Reply
Cap and rotor. Take a look.
Old    Charlie Zulu (Pad1Tai)      Join Date: Jan 2013       05-28-2013, 4:34 PM Reply
Second that on cap and rotor..... Seen it b4
Old    Chris (rio_sanger)      Join Date: Apr 2007       05-28-2013, 6:07 PM Reply
Thanks! Cap and rotor sounds like a good place to start, I'm hoping it's something that simple, and not a major problem...
Old    Michael Haseck (SacSurfer)      Join Date: May 2012       05-29-2013, 7:53 AM Reply
I'd go with the first response, fuel filters and cap and rotor. With that many hours can't hurt to do all those for under 100 bucks
Old    Brad Walker (humboldt9)      Join Date: Jun 2004       05-29-2013, 10:17 AM Reply
When was the last time you swapped out the plug wires? If you're changing the cap and rotor you might consider swapping those out too. Keep us posted on the solution I too keep my boat out at the river and I'm always looking for solutions like these if engine issues happen out there. It's a PITA to tow the boat back mid-season.
Old    Ryan (ryanw209)      Join Date: Jan 2010       05-29-2013, 10:56 AM Reply
I agree with cap and rotor. Mine was doing the same around 375 hours. Pulled the cap off and all the contacts were corroded.
Old    William Burell (williamburell)      Join Date: Sep 2011       05-29-2013, 11:27 AM Reply
There was a large batch of merc caps that were jacked up just fyi
Old    Chris (rio_sanger)      Join Date: Apr 2007       05-29-2013, 7:50 PM Reply
Bought new cap and rotor today, along with plugs, just in case. Now I can't wait to get back out and see if that solves the problem. I smell a "guys work trip" coming up soon
Thanks for your feedback, I'll keep you posted
Old     (Tengles)      Join Date: Jul 2012       05-30-2013, 4:58 AM Reply
I had a similar issue with my black scorpion. It would hesitate on take off and stall or hunt after backing off the throttle. I replaced all the usual stuff fuel filters, spark plugs and leads the rotor cap and none of this made much difference. Ended up using Subaru top end engine cleaner. You clean the throttle body with it then spray half the cans worth down the vacume line while running it at high idle. this did wonders made it like new and now runs perfect. Not sure if you can get your hands on it over there but a google search should point you in the right direction for a substitute product that does the same job.
Old    Chris (rio_sanger)      Join Date: Apr 2007       05-30-2013, 7:59 AM Reply
Thanks Tengles, I'll find a can of spray cleaner and bring it along.
Old    rzap (zap)      Join Date: Jan 2009       06-03-2013, 8:46 AM Reply
Been there, done that
Cap, rotor and a 1/2 a can of seafoam.... good to go
