Old     (ryin)      Join Date: May 2002       05-27-2013, 12:53 PM Reply
I am trying to install my amp and my original location was under the drivers console up top away from everything
But I am about 6" to short for my power and ground wires (10' of 4 AWG) to reach the amp. My other option would be installing the amp under the couch seat in a storage area which is right next the battery. Should I stick with my original location and solder on a little more wire? Or install close to the battery in the storage area?
Old     (boardman74)      Join Date: Jul 2012       05-27-2013, 1:01 PM Reply
Does anyone wet ever sit on the seat above that? Or do you ever put anything wet in that area. I guess to me high and dry is better!!
On a side note what is that tiny piece of plywood a backer plate for? That may need some attention especially if that is a tower leg as the shadow looks like it may be!
Old    kx250frider617            05-27-2013, 3:36 PM Reply
Do this, buy a power distr. block and run the extra foot of power wire, then if you want to add more amps later, you will be set up already. I wouldn't solder more power wire, that stuff is thick.
Old     (pprior)      Join Date: Jan 2012       05-27-2013, 3:52 PM Reply
Dist block and then short run is the way to go, if your original wire is up for it.
