Old    Ross (CTXxRoss)      Join Date: Apr 2013       05-21-2013, 10:09 PM Reply
So I can hear the motor running in the unit, has plenty of fluid in it, but the tab doesn't move at al... Gauge shows its at 50 but doesn't move either....
Boat is a 2000 Moomba Kamberra
Old    Phil White (philwsailz)      Join Date: Feb 2009       05-22-2013, 7:21 AM Reply
Check to make sure your solenoid valve(s) are opening. The pump gets power trim up or trim down, but two separate valves operate independently to allow positive fluid pressure on either side of the ram.
Phil
Kicker
Old    RB (boardman74)      Join Date: Jul 2012       05-22-2013, 7:43 AM Reply
When the pump runs what does it sound like? Does it just whine with a lazy easy sound and stay that way? Or does it sound like its bogging down, being held back and get worse the longer you hold it. If the valves aren't opening to allow fluid to the hydraulic cylinders(rams) the pump will sound like its bogging down as the fluid backs up and the pressure rises.
Old    Ross (CTXxRoss)      Join Date: Apr 2013       05-22-2013, 11:22 AM Reply
If you go one way it sounds fine, like its flowing freely, but reverse the direction and you can hear it bog down
Old    RB (boardman74)      Join Date: Jul 2012       05-22-2013, 12:20 PM Reply
If thats the case I would say you have a valve that is stuck like Phil suggested. I would also guess whatever direction the pump turns easily to is the direction the plate is all the way extended to. The direction it bogs in(that valve) is where I would start.
Old    Ross (CTXxRoss)      Join Date: Apr 2013       05-22-2013, 12:55 PM Reply
Ok... Thanks for the help yall!!!
