Old    Patrick Hardy (phardy)      Join Date: May 2013       05-21-2013, 10:56 AM Reply
Need help! Supra SSV 2006, my front Ballast bag fills up nicely but won't empty, any ideas?
Old    Dave (bcrider)      Join Date: Apr 2006       05-21-2013, 11:06 AM Reply
will need a little more info. What pumps, how many a bit of a diagram would help.
Old    Patrick Hardy (phardy)      Join Date: May 2013       05-21-2013, 11:15 AM Reply
Thx Dave, I'll get back to you with info.
Old    Michael (sprocketeer)      Join Date: Nov 2012       05-21-2013, 11:23 AM Reply
I had the same problem on my 2007 just a couple of weeks ago. I had to replace the drain pump with a Tsunami 800 and a straight barb fitting. I picked them up from wakemakers. It was probably good the pump failed because the housing completely broke when I took it out. I guess the bilge would have taken care of it...
This is a bandaid until I can replace the entire system with impellor pumps.
The stock Supra ballast for that generation sucks.
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       05-21-2013, 11:24 AM Reply
If you don't here the pump turn on when you hit the switch its probably your empty pump is out. There pretty cheap and easy to replace, I had to do it on my supra.
Old    Spencer (spencerwm)      Join Date: Feb 2009       05-23-2013, 10:10 AM Reply
Patrick,
Sounds like the drain pump. Could be the pump but also could be the breaker. Connect that pump directly to the battery to test it. it is doesn't fire replace it with an Attwood Tsunami 800. It will have the same 3/4" inlet and outlet as your factory pump.
Thanks,
Spencer
Old    Keith (Slicks)      Join Date: Feb 2013       05-23-2013, 9:10 PM Reply
I had the same problem with my 2008 Mobius LSV. Replaced a fuse under the dash and haven't any trouble since.
