Old     (Alex1978)      Join Date: Apr 2013       05-17-2013, 6:39 AM Reply
Hi, everybody.
My weight is 175lbs (80kg).
Board what I choose to buy (LF BOB Grind) has two size - 137 and 141.
Which one is better for me for cable and boat?
Great thanks!!
Best regards, Alex.
Old     (skiboarder)      Join Date: Oct 2006       05-17-2013, 6:52 AM Reply
How tall are you? I know some people will dispute that it makes a difference, but If you have a 23" stance a 141 will be tough to manage because your tip and tail will be huge.
Per your weight, you could ride either. I use height to split hairs.
Old     (Dmac420sj)      Join Date: Mar 2012       05-17-2013, 6:55 AM Reply
137 you don't want a big ole board.
Old     (skiboarder)      Join Date: Oct 2006       05-17-2013, 7:02 AM Reply
I'm 5-9 160 and I ride a 140 William off the wake and a 141 Schnook in the park.
Old     (stephan)      Join Date: Nov 2002       05-17-2013, 7:03 AM Reply
Definitely longer! I'm about 160 pounds and ride 138s but wish I was riding a bigger size. Especially at cable where the slower speed benefits from more surface area. I've been on a bigger board kick lately and look forward to expanding my quiver.
Old     (Rad_Matty_D)      Join Date: Jun 2011       05-17-2013, 8:29 AM Reply
gotta go 141.
You won't regret it. the larger board is more for your size and will be more buoyant on the water and produce more speed through the wake and produce pop for your weight.
