Old     (jhartt3)      Join Date: Jan 2012       05-11-2013, 6:24 AM Reply
So i just got delivery on my fat sacs the other day. They appear to use the same pump and ports as the sumo sacs. but every time i try to fill the sac the pump will pump more water than the sac can accept and it over flows. has anyone had this issue with their sumo sacs?
Thanks,
Jess
Old     (jhartt3)      Join Date: Jan 2012       05-11-2013, 6:32 AM Reply
to clarify a bit more ... water will push out past where the hose is connected on the in port.
Old     (jhartt3)      Join Date: Jan 2012       05-12-2013, 5:05 AM Reply
anyone?
Old     (ferral)      Join Date: Sep 2007       05-12-2013, 9:29 AM Reply
Is this plumbed into your boat with vent lines? Or are you using a separate pump to fill on the seats/floor? If no vent or a separate pump, you have to stop the pump before you overfill. If you overfill you should expect it to leak back out.
Old     (jhartt3)      Join Date: Jan 2012       05-12-2013, 10:03 AM Reply
I'm just using a pump plugged into my acc. The sac only gets a few gallons in it before it starts to push out thru the opening. Like the opening isn't big enough to accept the amount of water being pumped.
Old     (spencerwm)      Join Date: Feb 2009       05-13-2013, 8:30 AM Reply
Jess,
Sounds like an issue with the Link Valve port on top. If the internal plunger does not open all of the way the bag will not be able to accept all of the water that you are trying to pump in. Make sure there is nothing obstructing the valve system. If it seems like the bag has a defect call the-house and warranty them.
Thanks,
Spencer
Old     (jhartt3)      Join Date: Jan 2012       05-13-2013, 10:11 AM Reply
yeah i have looked at that plunger setup on all the bags... just strange that i would get 2 defects... maybe even 3 i didnt bother to test the third after the first 2 did it... i'm in contact with the company i purchased from ... we'll see what gets accomplished. I have depressed the plunger my self and it appears to be functioning correctly.
Old     (hco)      Join Date: Jun 2006       05-13-2013, 12:23 PM Reply
If there are o-rings on the pump make sure that they are in place and still in good condition.
Old     (jhartt3)      Join Date: Jan 2012       05-13-2013, 12:52 PM Reply
yep they were brand new ... i have a new set on its way today. hopefully these work correctly. my guess is it is a problem with the pump... meaning the connector may not be pushing the valve in far enough... so we will see when this set gets in.. Props to DJs boardshop on the customer service thus far.
Old     (simplej)      Join Date: Sep 2011       05-13-2013, 2:07 PM Reply
i have that problem on a old. the gasket on my pump is shot for the inlet pump though, check there as well.
Old     (HotTubTony)      Join Date: Jun 2013       06-27-2013, 8:55 AM Reply
Boarder 42,
I am wondering if you have an update on this issue? I bought the same sac from DJ's Board Shop (http://www.djsboardshop.com/p-44235-...40lb-pump.aspx) and have the same issue.
Thanks!!!
Old     (jhartt3)      Join Date: Jan 2012       06-27-2013, 9:00 AM Reply
Yep... here is what you need to do email liquid force customer service. The issue was the Orings were incorrectly sized. They will mail you 2 orings. They didnt know this when i went thru the process so they upgraded me to 3 600lb sumo sacs and a sumo pump... so i got the hookup ...but now i hear they are just sending out new orings to people.
Old     (HotTubTony)      Join Date: Jun 2013       06-27-2013, 9:03 AM Reply
Contact Liquid Force or DJs?
Old     (jhartt3)      Join Date: Jan 2012       06-27-2013, 9:38 AM Reply
either or... both
Old     (HotTubTony)      Join Date: Jun 2013       06-27-2013, 9:43 AM Reply
I appreciate it B42!!! I have started that process and look forward to the extra weight in the boat!
Old     (jhartt3)      Join Date: Jan 2012       06-27-2013, 9:51 AM Reply
you will love it...
Old     (fouroheight68)      Join Date: May 2006       06-27-2013, 11:53 AM Reply
Why contact liquid force? The pumps/bags are made by straightline
Old     (fouroheight68)      Join Date: May 2006       06-27-2013, 12:04 PM Reply
Nevermind, didnt know they were owned by liquid force. Spoke to them and it sounds like a larger o-ring is needed
