Old    Boarder 42 (jhartt3)      Join Date: Jan 2012       05-13-2013, 3:08 PM Reply
So i have a headunit that will push out 50W peak to 4 speakers so 200W total. It is turning off on me if i turn my speakers up too loud. I have read i need to replace the power wire. with a larger wire. What guage do i need to use or would you stereo guys recommend?
Thanks,
Jess
Old    JP (jpaul)      Join Date: Mar 2008       05-13-2013, 5:14 PM Reply
14 is fine. Check your ground first, should be short and contact needs to be clean.
Old    TigeMike (chpthril)      Join Date: Oct 2007       05-13-2013, 6:15 PM Reply
wire gauge will depend on the total length. If its a short run to the battery for the head-units B+ and GND, then 14ga is sufficient. It the run is long, then step up to 12ga.
Old    Russ Constable (Midnightv10)      Join Date: Feb 2012       05-13-2013, 8:35 PM Reply
Getcha a couple lengths of 2/0 power and ground and run them up to the head unit. You'll need to find some 2/0 to 14 reducing crimps though
Old    Chris Dirty (Dmac420sj)      Join Date: Mar 2012       05-13-2013, 11:41 PM Reply
Hey man you don't need 12 ga. Off your hu. 16 is fine.
