Old     (hillbilly)      Join Date: Aug 2002       05-04-2013, 12:14 PM Reply
How in holy heck do I get that nut loosened........If I have to take out the transmission does fluid go everywhere or is it only going to spill if I tip the tran/v drive assembly over?
2007 Moomba LSV is the boat...
Thanks JH
Old     (boardman74)      Join Date: Jul 2012       05-04-2013, 3:48 PM Reply
Sometimes they get on there pretty tight. Doesn't help that the shaft wants to turn also. Trick a shop taught me a while ago was to put a board(2x4) between the prop and the hull so the prop/shaft can't turn. Then get a good sized breaker bar on it and you should be able to get it.
Old     (john211)      Join Date: Aug 2008       05-04-2013, 4:49 PM Reply
Yeah you might get a cheater (a pipe that fits over your socket wrench) that is 4, 5 or 6 feet long. Be prepared to land on your tailbone when the nut breaks loose. You will be tensed like you're doing the mightiest deadlift in your life ... and then ... BOOM , ... all of the resisting force is instantly gone.
Old     (tonyv420)      Join Date: Jul 2007       05-04-2013, 8:47 PM Reply
i use a 2x4
Old     (drive139)      Join Date: Apr 2007       05-05-2013, 6:58 AM Reply
The manufacturer does not recommend removing the coupler since it is pressed on and balanced properly from the factory. I used to work at a Supra/Moomba dealership and you can remove the shaft without removing the coupler. You have to remove the prop, unbolt the vdrive, unbolt the strut, and remove the rear floor panel and then the shaft will slide out over the top of the gas tank.
Old     (alexair)      Join Date: Oct 2008       05-05-2013, 7:54 AM Reply
Therefore on the direct drive boats you have to remove the engine with transmission. OK? And NEVER do order the shaft only. Even if it goes like separate part.
Is propeller balanced with drive shaft assy also?
Old     (john211)      Join Date: Aug 2008       05-06-2013, 9:06 AM Reply
My remarks are in error. I was referring to how much force I had to apply to get the prop puller to loosen the prop. And perhaps you already know, but you just loosen the nut and leave it on (to keep the prop from falling to the ground ... you won't be around to catch ... you might be rolling on the ground like you're on fire).
Old     (saceone)      Join Date: Jan 2009       05-06-2013, 4:52 PM Reply
Use a 2*4!
