Old    J J (jjolin01)      Join Date: Oct 2012       04-25-2013, 3:31 PM Reply
I just rewired my new stereo and its sounds great except there is a loud pop when i turn off my stereo. I have HU, WS-420, 3 amps. I wired it according to an old threat that Phil from Kicker wrote and i'm not sure where i went wrong. Any suggestions?
Old    Russ Constable (Midnightv10)      Join Date: Feb 2012       04-26-2013, 11:06 AM Reply
How do you have your amp turn on leads wired? I run all mine off a relay from the head unit. no pop
Old    Charlie Zulu (Pad1Tai)      Join Date: Jan 2013       04-26-2013, 4:05 PM Reply
I don't see how the blue wire would cause this... can you explain..
Old    J J (jjolin01)      Join Date: Oct 2012       05-06-2013, 7:59 PM Reply
Thanks Russ, I ended up putting the remote wire on a switch and just turn it off before i turn the stereo off. I do have a relay, which point did you put the remote wire? I would think the same as the HU red wire.
Old    Russ Constable (Midnightv10)      Join Date: Feb 2012       05-08-2013, 2:59 PM Reply
Jeff,
Take the remote wire off the switch and wire up the relay like this. Should solve your problems.
