Old     (tdickman4)      Join Date: Feb 2013       04-22-2013, 10:33 AM Reply
I have a 2006 Supra Launch 22SSV with stock ballasts. 400 on each side with 650 in the ski locker. What is the best setup for this boat that people have found out?
Old     (dreamer)      Join Date: Nov 2008       04-22-2013, 11:36 AM Reply
Get as much weight in your surf side locker as possible and fill your ski sac to the max. Wake plate all the way up. Have all of the passengers sit on the surf side as far back as possible and ride about 10-10.5 mph.
Old     (randyr12)      Join Date: Feb 2013       04-24-2013, 12:55 PM Reply
I would switch out your rear ballast bags to 750's or 1100's. If you go with the 1100's you will need to beef up your hinges at the bottom of the divider. Go to wakemakers.com they have a complete ballast upgrade package for the 22ssv. You will need the additional fittings and tube extensions as well.
