Old    Cole K (SkySki)      Join Date: Feb 2010       04-15-2013, 6:22 AM Reply
Started putting the new Fresh Air Exhaust. Still needs some adjustment. Not quite finished. Put everything on and I think I need a little longer exhaust hose. FAE is sending it out today. Here are some pictures of how far I have gotten.
I got lucky and was able to use a couple of screws from my swim platform to hold the bar. Once I get the new hose I will be able to cut and mount the two poles.
Old    E (22vdrive)      Join Date: Apr 2010       04-15-2013, 6:40 AM Reply
How did the wave look with it on? I've been dying to get one on my f21. I have the same 4" single exhaust pipe.
Old    Nicolas Kohler (monkey_butt)      Join Date: Sep 2011       04-15-2013, 6:51 AM Reply
you still have the fun job ahead of you drilling the holes for the screw/bolt thru the stainless steel pipe ... I hated that one - especially as I cut the pipe in the first round too long and had to do it twice ...
Old    Cole K (SkySki)      Join Date: Feb 2010       04-15-2013, 7:47 AM Reply
I haven't tested the wake yet. Need the hose first.
I have a pretty good drill press for the holes and hopefully my band saw will make the cut decent on the poles. If I didn't have those two pieces, I would be dreading the job.
Old     (CarZin)      Join Date: Feb 2011       04-15-2013, 7:58 AM Reply
What are the advantages of using a Fresh Air Exhaust on an engine that is already CAT'd and has ultra low emissions, like the 343? Were you trying to reduce the noise?
Old    E (22vdrive)      Join Date: Apr 2010       04-15-2013, 8:02 AM Reply
Reducing noise and annoying vapor fumes out out of sight. This is my next upgrade
Old    Cole K (SkySki)      Join Date: Feb 2010       04-15-2013, 8:09 AM Reply
Both reducing the noise (#1 reason) and also getting rid of vapors (#2 - when it was cold this winter, you could see the vapors rolling back into the boat - made my hypochondriac wife say she started feeling ill. She never had a problem before, only once she could see it).
Old    Anthonyv911 (tonyv420)      Join Date: Jul 2007       04-15-2013, 11:06 AM Reply
you will love it, it should not affect your wave at all, (at least mine doesn't)
Old    DC (durty_curt)      Join Date: Apr 2008       04-15-2013, 9:18 PM Reply
wow! I Had No Idea yours only Needed A Couple T bolt Hose Clamps, Mine Looks Like Its Breathing BY Hose Clamps!
Also The choke hold Capability Of Using T Bolt Hose Clamps Instead Of What They send With The Kit
T bolt Choke Hold
Regular hose Clamps Choke Hold
Old    Cole K (SkySki)      Join Date: Feb 2010       04-16-2013, 5:41 AM Reply
That is a great shot DC. Breathing by hose clamps
