Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 29, 2003
Old    wakeandsno            08-25-2003, 3:56 PM Reply
Ok, for you guys who are regulars at the cable parks, can you give a detailed description of how exactly to get big air on the cable? Like how should you cut, where should you cut (i.e. at the corners), when should you release to get the most pop, etc.
Any tips would be appreciated.
J.
Old    blind5            08-25-2003, 9:04 PM Reply
J. the best way to get air at the cable is to actually get behind someone that can. follow the exact path of them and learn the same cut as them, just make sure to really bend your knees and launch. remember on the cable you have to do a trick were the board goes out behind you. such as a raley, roll-to-revert. good luck
Rob Corum
Old    Tony Neal (aneal000)      Join Date: Feb 2002       08-26-2003, 1:48 PM Reply
it really helps if you are goofy footed, then you can do a heel side cut around each corner. If you are regular footed you can do tricks if you cut super hard when you leave the dock.
