Old     (Carlos35)      Join Date: Apr 2013       04-01-2013, 11:31 PM Reply
Does anybody know the freeboard measurement of a 2005 Supra 21V as i can only find reference to the draft of 25".
Also while I am at it the 2011 Sunsport 20V freeboard measurement would be awesome to know also.
cheers guys!
Carl
Old     (ralph)      Join Date: Apr 2002       04-02-2013, 1:12 AM Reply
I have never seen freeboard published before. Difficult figure to get a handle on because it changes depending on where on the water line you measure and how much weight the boat is carrying and where.
Old     (Carlos35)      Join Date: Apr 2013       04-02-2013, 3:12 AM Reply
I know but was trying to work out the height difference between the 21v and 20v under the same weight and conditions
Old     (tyler97217)      Join Date: Aug 2004       04-02-2013, 6:59 AM Reply
The 21V will have much more freeboard than the 20V. In fact the 21V probably has more freeboard than most boats in the 21' segment. Not sure what actual measurments are, but between the 21V and the 20V it will be significant
Old     (xstarrider)      Join Date: Jun 2007       04-02-2013, 10:07 PM Reply
I will echo Tyler
The 20V nose also rides much lower to the water. The seat bases are a bit lower to the cabin floor as well on the 20V.
Old     (Carlos35)      Join Date: Apr 2013       04-03-2013, 3:00 AM Reply
Thanks Guys, was tossing up between an 05 21V and a 2011 20V. Ended up spending the more coin and got the 21V with 10 hours and full Supra options and more. Guess now I will have to live with the lesser freeboard, but sure it won't make much difference now!
Old     (tyler97217)      Join Date: Aug 2004       04-03-2013, 6:27 AM Reply
You got the 21V or the 20V? You said 21V but then said going to have to live with lesser freeboard. Only 10 hours as well. I am assuming you went with the 20V? Congrats on your new boat. Pics now.....
Old     (Carlos35)      Join Date: Apr 2013       04-04-2013, 4:10 AM Reply
Yes I went with the 20V and pick it up next week.
http://www.boatsales.com.au/boats-fo...&Ridx=3&eapi=2
Old     (Carlos35)      Join Date: Apr 2013       04-04-2013, 4:12 AM Reply
Now that I have it does anybody have any ballast setup tips?
