Old     (Dmac420sj)      Join Date: Mar 2012       03-27-2013, 10:40 AM Reply
Is tinned wire necessary for speakers amps etc. ?
Old     (chpthril)      Join Date: Oct 2007       03-27-2013, 11:06 AM Reply
no
Old     (david_e_m)      Join Date: Jul 2008       03-27-2013, 12:45 PM Reply
Tinned wire is normally used for off shore boats.
In fresh water you rarely see it. 10 years later a non-tinned 4-gauge cable going into a distribution block shows no signs of oxidation.
We crimp and solder on nickel plated lugs so essentially the exposed part of the wire is tinned.
Don't worry about 'tinned' wire. Worry more about lugs with cheap coatings and cheap wire that isn't cooper.
David
Earmark Marine
Old     (brianinpdx)      Join Date: Aug 2009       03-27-2013, 7:57 PM Reply
DMC - I'd say no to the tinned wire. Oxidation will vary a lot depending on what part of the country you are in. The larger issue is getting legit cables in the first place. A few years back many accessory companies tried to save a few bucks on their product costs by significantly undersizing the power cable core and also substituting CCA from old fashioned copper. They figured consumers wouldn't notice this change. And frankly, many don't. It don't make it right for your system by a long shot.
My advice is find real copper cables and not worry about the tinned aspect. If you need help with which brands to stay away from, PM me. I'll share more specific info. Also price is a huge factor here. Real copper costs 2-3x the CCA stuff.
-Brian
Exile Audio
Old     (Dmac420sj)      Join Date: Mar 2012       03-27-2013, 8:51 PM Reply
Right on thanks guys
Old     (nitrousbird)      Join Date: Sep 2008       03-28-2013, 1:23 PM Reply
My '01 Malibu spent its first 10 years on a covered lift with the original owner (I keep it garaged year-round). No tinned wire from the factory and even the power/ground lugs were not tinned, no corrosion issues at all.
I did go with tinned lugs this time, but just because I found a good deal on them.
Old     (Dmac420sj)      Join Date: Mar 2012       04-22-2013, 5:31 PM Reply
so when running new speaker wire and amp cables etc. how do i make sure the wire is good?and also what would be the differencebetween different qualities?
Old     (bftskir)      Join Date: Jan 2004       04-22-2013, 6:07 PM Reply
you go get it from Topside Marine
Old     (Dmac420sj)      Join Date: Mar 2012       04-22-2013, 6:15 PM Reply
great wire just alot of $
Old     (bftskir)      Join Date: Jan 2004       04-22-2013, 6:18 PM Reply
but you would be sure the wire is good.
Old     (Dmac420sj)      Join Date: Mar 2012       04-22-2013, 9:15 PM Reply
knukonceptz.com answered my own question. 1/8 of the price of other places and high quality!!
Old     (acurtis_ttu)      Join Date: May 2004       04-23-2013, 7:27 AM Reply
i've used welding cable in the past.
Old     (shawndoggy)      Join Date: Nov 2009       04-23-2013, 7:32 AM Reply
darvex.com has very good prices on stinger products. I've used the knukonceptz stuff too and it's comparable.
