Old     (Lemonade)      Join Date: May 2015       07-06-2017, 1:31 PM Reply
Back to the top...
Old    Nacho (denverd1)      Join Date: May 2004       07-06-2017, 2:48 PM Reply
great shots!!
Old    Jay Wedsted (jbird)      Join Date: Jun 2011       07-06-2017, 11:50 PM Reply
Old    Jay Wedsted (jbird)      Join Date: Jun 2011       07-06-2017, 11:51 PM Reply
Old    Markj (markj)      Join Date: Apr 2005       07-07-2017, 12:12 AM Reply
Funny thing is Sangers don't even need any weight to look slumped. Is there a boat out there with lower freeboard?
Old    Walt (Walt)      Join Date: Jan 2003       08-17-2017, 7:43 PM Reply
Drone shot >
Old    Rick (CALIV210)      Join Date: Jun 2015       08-18-2017, 2:18 PM Reply
You are definitely right but its hard to get away from the racing heritage Sanger has which is where the low freeboard comes from I'm sure . Which is the reason nothing else handles as well as a Sanger either .
Old    Markj (markj)      Join Date: Apr 2005       08-18-2017, 2:29 PM Reply
MB has a few design cues that I'm sure remain only because of MB himself too.
Old    Rick (CALIV210)      Join Date: Jun 2015       08-18-2017, 2:34 PM Reply
I'm sure your right about that !!
I love this thread I wish we had more Sanger guys in here . All this talk of G23's and X this and LSV that I'm lucky if those dude even let me look at there boats lol
Old    Larry (larry1167)      Join Date: Jun 2010       08-20-2017, 8:34 AM Reply
Love my V210
Old    Nacho (denverd1)      Join Date: May 2004       09-06-2017, 1:38 PM Reply
Me too. Awesome boats. bought mine because I read such great reviews on this site. does everything I want it to and more.
Old    David Koenig (DaveMK)      Join Date: Feb 2018       02-20-2018, 11:50 AM Reply
I just bought a 2014 V327 LTZ! We are picking it up in a few weeks and heading to Phoenix to get it on the water. It has the factory ballast system with small hard tanks in each rear locker, and the original owner added additional pumps and another 250 lb bag in each locker. Does anyone know how big a ballast bag will fit into the V237 rear compartments with the hard tanks? I'd really like to maximize my "Slumpling"
Old    Nacho (denverd1)      Join Date: May 2004       02-22-2018, 11:58 AM Reply
with tanks? not sure. without they hold 1100s. I guess you could leave the hard tanks and put a 750 on top. you'd be leaving some weight on the table as I'm sure it won't hold as much without the tank in there. yank 'em out man.
Congrats! let's see some pics
Old    Mike Pleasance (mpleasance)      Join Date: Feb 2009       02-22-2018, 11:50 PM Reply
I've got the same boat and don't think you will get much in the locker with the 400 lb hard tanks left in.
The tanks run along the side of the locker and with all the paneling in place the lockers are pretty small. I'm just about finished removing the hard tanks and putting in 910 lb bags.
The dimensions of the bags I got are 40" long x 25" wide x 20" tall. I haven't filled them yet, but it doesn't look like a bigger foot print would fit. The lockers are a bit strange, with quite a bit of room above and behind the pumps. I'll probably tuck some lead in there to get around 1000 lbs in each locker. I'm planning to get around 600 lbs of lead, most which will go in the bow because there is very little space for water ballast up there.
I'll take a few pictures next time I'm at the boat.
I'd recommend pulling the tanks too, there is so much wasted space with the configuration of the hard tanks. I had to cut them half to get them out, but it wasn't too bad. Get bags and hook'em up to the stock pumps and the additional pumps the previous owner put in for faster fill/drain times.
Old    Nacho (denverd1)      Join Date: May 2004       02-23-2018, 3:11 PM Reply
with tanks, bags would put WAY too much pressure on divider walls if it did work. best to pull them. you can work the tanks out, but its not easy.
40x25x20 bags sounds like 750s. just put lead underneath them
Old    Mike Pleasance (mpleasance)      Join Date: Feb 2009       02-23-2018, 4:15 PM Reply
My mistake on the bag dimensions, 45 x 25 x 20 listed at 910 lbs from Wakemakers.
Have you pulled tanks the 400 lb hard tanks from a 2014 V237? They extend 12-18" beyond the end of the locker under the back rest of the corner seat. There is a bulkhead (that didn't seem movable) that prevented much movement of the hard tank. To me, it didn't even seem close. I'm curious because I puzzled over it for quite some time but didn't see it happening without removing significant parts of the boat.
Anyway, the plumbing part was straight forward and I'm looking forward to spring to see the difference.
