Old    Brett Treiber (pc_sledge)      Join Date: Jan 2006       03-01-2013, 5:57 AM Reply
I was thinking about adding LED's in my cupholders. What is the easiest way to accomplish this? Anyone have any luck with prewired stainless steel ones? Pics of DIY installs? What did it end up costing you per cupholder?
Old    Chase Tillett (tn_rider)      Join Date: Dec 2009       03-01-2013, 6:03 AM Reply
I was wondering the same. What do you guys reccomend as far as LED's? I want an LED ring that is closer together giving the "glow" look and not show as many of the individual LED's around the Cupholder.
Old    William Burell (williamburell)      Join Date: Sep 2011       03-01-2013, 6:10 AM Reply
As an alternative I bought the 2 dollar single led's from oznium and drilled a very small hole in the bottom of the cupholder just big enough for the wire.. The leds are wp and self adhesive. Put a drop of silicone over the hole and was done in 2 minutes. It shines up through the cupholder instead of around but I actually like the look better. Plus with 8 cupholders I saved over 150 bucks on useless rings
Old    Sumit Goyal (sgoyal)      Join Date: Feb 2013       03-01-2013, 6:48 AM Reply
I think William talking about this one. I might be wrong
Old    Bryce Pool (bryce2320)      Join Date: May 2012       03-01-2013, 6:54 AM Reply
Tige Mike ran a deal on tige owners and cut us a deal on cup holder rings and speakers. It came with the 300/p 5m led strips with leads soldered on. I bought new SS cup holders to replace my old black ones and I think they look good. Sand the edge of the ring and it'll frost it where it disperses the light so u cant see each individual LED
Old    Bryce Pool (bryce2320)      Join Date: May 2012       03-01-2013, 6:56 AM Reply
If u wanted rings to go with a single led in the bottom
Old    Harold Hemming (h20king)      Join Date: Dec 2009       03-01-2013, 7:05 AM Reply
The light effect you get depends on what finish you get on the rings. I went with clear rings with no frosting of the plexi.I think the clear rings emit more light and give a nice glow effect. I also think the the color light you chose plays a factor as well. For example a blue led puts out more light than red so you might need to have one side or another frosted to get the effect you are looking for. Dave from earmark could answer the question they have a ring for every application.Here are a couple pics sorry the night pic is not the best but it gives you the idea.
Old    Sumit Goyal (sgoyal)      Join Date: Feb 2013       03-01-2013, 7:17 AM Reply
I like clear rings too. I created speaker rings with clear acrylic (9mm) and used 300led/5050SMD. I really like the light effect.
Old    William Burell (williamburell)      Join Date: Sep 2011       03-04-2013, 6:27 AM Reply
actually they are these. Pack a pretty good punch and are flat.
http://www.oznium.com/prewired-surface-mount-led
Old    lynn carnacchi (launch_sl)      Join Date: Apr 2003       03-07-2013, 1:53 PM Reply
Mine
Old    lynn carnacchi (launch_sl)      Join Date: Apr 2003       03-07-2013, 1:54 PM Reply
More
