Once you pick a white gelcoat put about a quarters worth on a piece of cardboard. Add 2-3 drops of hardener (should come with the gelcoat), take a small paintbrush and dob the gelcoat into the hole. Take a piece of green or blue painters tape and place very lightly over the repair. Let dry for a day. Drys better in warmer weather. Peel the tape, if there is still a low spot, repeat previous steps....
Wet sand with 1500 in one direction until smooth, wet sand with 2500 in one direction to remove 1500 scratches. Buff with rotary buffer using Meguiars diamond cut 105 compound. Wax, done...
