Old    Seth Campbell (raceman121)      Join Date: Nov 2012       02-12-2013, 6:07 AM Reply
any one use these? Im just looking for some cheep weight to through around to find out my boats perfect surfing set up I have a fly high and the tsunami pump. will the fittings be the same like to fid the pump i have and will they pop? http://www.aerialwakeboarding.com/v/...ccessories.asp
Old    William Burell (williamburell)      Join Date: Sep 2011       02-12-2013, 6:48 AM Reply
I got some for xmas. They look fine to me but they use the waterbed fittings. You can but some fittings from wakemakers to fit the aerial bags to your reg pump fittings. They are like 19 bucks.
Old    Brandon (Gnargnar)      Join Date: Aug 2012       02-12-2013, 8:02 AM Reply
They're outta stock on the 350s and 550s til like mid April. I went with sumo straight lines from wake makers and got them yesterday. Only thing that made me stray away aside from the back order is there's no fittings on bottom of bag if you ever want to plumb them in. But definitely too cheap to not want em
Old    Chris Bolding (chris_b)      Join Date: Feb 2007       02-12-2013, 10:04 AM Reply
I have 2 - 550lbs bags that have never been used that I would be sale if someone wanted them.
Old    Justin (jrw160)      Join Date: Oct 2006       02-12-2013, 11:16 AM Reply
They are decent for the money. They two piece bags. There is an inner bladder and an outer vinyl protective layer. I had trouble getting the fill holes to line up on the inner and outer part. They also use waterbed fittings which always leaks water all over the place. I replaced mine with a larger fly high bag. I have two 350s I am looking to get rid of if anyone is interested.
