Old    Kane Vahn (kvold)      Join Date: Feb 2013       02-10-2013, 6:24 PM Reply
What is the difference between the Harley Board, and the Harley Grind board?
Old    Ben Wilcox (benjaminp)      Join Date: Nov 2008       02-10-2013, 6:42 PM Reply
Did you read the product description? Its not mind blowing. One has a grind base, one does not. Get the grind base if you plan on riding cable. Otherwise, save yourself the weight and get the regular base.
Old    Ben Ax (hawkeye7708)      Join Date: Feb 2007       02-10-2013, 7:43 PM Reply
Yupper. Grind will have a more durable base if you're going to be beating it up a bit. Not a ton of difference. Rails and cable, get the grind base. Boat, get the standard.
