Old                08-24-2003, 10:02 PM Reply
hello i can't seem to land my hs bs 180s. I cut out just like im going to do a hs fs 180 (which i have no problem with), i pop off the wake, intiate the spin, i can get the board going straight and my lead hand on the handle and my rear hand off, but i always seem to fall backwards! can this be because i am looking backwards when i land? any comments would be helpful thanks.
Old    andrew (tantrum999)      Join Date: Jun 2003       08-24-2003, 10:13 PM Reply
Only go wake to wake, Pass the handle late or after you land richie. If your landing backwards then you maybe not putting the weight on your toes? to sort your problem out step by step then i would try facing the nose of the board more towards the boat on landing rather than cutting away too much, this will give you a smoother landing. hope this helps
(Message edited by tantrum999 on August 24, 2003)
Old    Blabelmooch (blabel)      Join Date: Jul 2001       08-24-2003, 10:38 PM Reply
Here's a great article that should help you
http://www.wakeworld.com/Tricklist/TrickTip010.asp
