Old     (MattWake22)      Join Date: Jan 2013       01-22-2013, 10:05 AM Reply
Hey guys. I'm pretty certain I am going to purchase the AJ hyperlite system boot. I was wondering of anyone could help me with a sizing question. I wear a 9.5 shoe and the sizes available for the boot are a 9 and a 10. Does anyone have any experience with the AJ boot? I'm wondering if it runs large or small. Thanks in advance for your help
Old    Small Light (stephan)      Join Date: Nov 2002       01-22-2013, 11:14 AM Reply
This year especially it runs very true to size. I think it will be more about personal preference. How do you like your boots to fit? I like a tight boot and would choose the size down.
Old    Tom Pazerunas (tom_paz)      Join Date: Jan 2003       01-22-2013, 12:20 PM Reply
Matt - first off I think you will like the systems, especially if you like minimal heel/toe lift and increase response and support. I know I wouldnt trade mine for anything.
But I just wanted to confirm what Stephan said. the 2012 system boots as a whole used a different last (mold) to create the boots, and as a result the boots came out a little smaller than most shoe sizes. For example, I wear a 10 by most shoe mfg's and for my 2012 murrays I grabbed an 11.
However, for 2013 there was a different last used to make the boots, and as a result the 2013 boots will fit very similar to most shoe sizes. This year I grabbed a size 10 pair of Process boots, and I couldnt be more excited to get out and ride them.
With all that said, if you want to heat mold your boots, its possible for that extra 1/2 size to be packed out or filled in from the heat molding process, depending how much room is in your boots. The molding process wont change the size of the boots significantly, but if your toes are cramped up front, it will expand a little so they are more comfortable. Or if there's some extra room in the toe box, the foam will puff out and fill in some of the dead-space. Again with what Stephan said there is some personal preference involved.
To simplify things:
2012's - go for size 10s
2013's - try them on if you can. If not, and you like a tight boot, get 9s. If you like some extra flex or "wiggle room" then go for the 10s.
Hope this helps, and hope you dig your new systems.
Old    Shon G. (shon_g)      Join Date: Apr 2007       01-22-2013, 1:16 PM Reply
If you have a shop close enough to stop in then i suggest trying them on.. Thats the only way to find out how they feel and fit. Support your local shop!
Old    DTB (DatTexasBoy)      Join Date: Aug 2012       01-22-2013, 9:25 PM Reply
Yes Aj's are running very true to size in the 2013 boot. Great boot by the way.
