Old    "G" (grant_west)      Join Date: Jun 2005       01-14-2013, 11:47 AM Reply
My boat since day 1 has been plagued with overflow issues from the check valve. The check valve is a one way valve that lets the gas tank "Vent" but not suck in water. The problem is the vent sits atop the gas tank and the vent hole on the side of the boat is either at the same height or lower then the vent on the tank. I installed a plastic check valve a while back but it didn't seem to do much. I still have gas spewing out the side of my boat when I have a full tank and go around a right hand corner.
I'm asking for some advice on the proper way that a check valve system should be run or installed. I'm tired of having gas run down the side of the boat and eat away my decals ect.
Thanks in Advance
"G
Old    Preston (Bamabonners)      Join Date: Jul 2011       01-14-2013, 12:15 PM Reply
what boat do you have? many people have found a simple fix for this on various brands.
Old    "G" (grant_west)      Join Date: Jun 2005       01-14-2013, 12:28 PM Reply
Sorry I should have listed it I have A 02 Air Nautique .thats a direct drive boat
Old    Bryan Locke (gwnkids)      Join Date: Nov 2003       01-14-2013, 7:00 PM Reply
This is what I used
http://www.skidim.com/prodinfo.asp?number=LG-50
Old    "G" (grant_west)      Join Date: Jun 2005       01-14-2013, 9:22 PM Reply
Gnkids: that looks like what I need I just placed a order for one.
How did you mount yours Vertical or horizontal.
Old    Bryan Locke (gwnkids)      Join Date: Nov 2003       01-15-2013, 11:25 AM Reply
Vertical
I also relocated the vent up closer to where the observer seat is (we surf alot ant the rub rail it close to the water line) put a 90 coming down then a 90 out to the tank
Old    "G" (grant_west)      Join Date: Jun 2005       01-15-2013, 12:22 PM Reply
Sorry fro the lame drawing
Old    "G" (grant_west)      Join Date: Jun 2005       01-15-2013, 12:33 PM Reply
So the Idea will be to try and run the over flow line as close to the underside of the deck (highest point) and then back down and up to the over flow in the back. I know in the drawing Im showing the line running line 90's but it will swoop I dont like the Idea of gas sitting in the low point of the line. Can I run the Valve in a horizontal position???
Old    "G" (grant_west)      Join Date: Jun 2005       01-15-2013, 12:38 PM Reply
Ideas???
Old    Bryan Locke (gwnkids)      Join Date: Nov 2003       01-15-2013, 2:07 PM Reply
The first example is the correct way. The valve has a ball inside that must be at a 55 angle to flow (roll) and seal properly.
I dont know if you can see the photos in this link but it will give you a good visual.
http://www.themalibucrew.com/forums/...nstallation-r2
It has worked flawless for me. I trailer and after filling up I would always watch the gas pour out of the overflow, now it all stays in the tank.
Old    "G" (grant_west)      Join Date: Jun 2005       01-15-2013, 3:10 PM Reply
Looks like the check Valve you recommended is no longer available from Skidim
I got this email from them after I placed the order.
The Air/Fuel separator you ordered has been superseded with a less expensive, good alternative product, cost is just $24.99.
Item #31612. We no longer have the expensive one in stock. May we substitute for you?
I have the Attwood one right now. That's the cheeper one they are referring to.
Any ideas on another source
Old    Bryan Locke (gwnkids)      Join Date: Nov 2003       01-15-2013, 3:27 PM Reply
Bakes may have them
866-993-2253
http://www.bakesonline.com/detail.aspx?ID=1314
Old    "G" (grant_west)      Join Date: Jun 2005       01-15-2013, 3:40 PM Reply
Bryan; Thanks they have it
Old    Bryan Locke (gwnkids)      Join Date: Nov 2003       01-15-2013, 4:22 PM Reply
Anytime, you have helped us just nice to give back.
Old    "G" (grant_west)      Join Date: Jun 2005       01-29-2013, 9:35 AM Reply
My Check Valve showed up yesterday.
Looking over the instructions, I orderd it from South Carolina and its made in Modesto Ca,
Lol I was 2 mins from the factory yesterday.
Old    "G" (grant_west)      Join Date: Jun 2005       01-29-2013, 9:38 AM Reply
Looks like I'm going to have to install it in this Configuration. I'm going to try and come right out of the tank vent and install it at a 45 and them run the line down hill to the vent
Old    "G" (grant_west)      Join Date: Jun 2005       02-02-2013, 10:13 PM Reply
Started installing
Old    "G" (grant_west)      Join Date: Jun 2005       02-02-2013, 10:14 PM Reply
This is it on the mount
Old    "G" (grant_west)      Join Date: Jun 2005       02-02-2013, 10:19 PM Reply
This is its location not Ideal but it will do the trick
Old    "G" (grant_west)      Join Date: Jun 2005       02-02-2013, 10:37 PM Reply
Mount
Old    "G" (grant_west)      Join Date: Jun 2005       02-03-2013, 8:11 AM Reply
The top of the check valve is at the highest point and the hose slopes back to the vent with "no trap"
Or Dip up and down in the line
