Old     (Jake)      Join Date: Nov 2012       12-28-2012, 5:45 PM Reply
I've got one pair of rev 10 powered by a Jl hd 750 on my pontoon boat. All I can say is hot damn..these things are bad ass..the mid bass is crazy I did not expect it at all..watching vids on YouTube do these things no justice..very happy with my speaker and amp choice..can't wait to hit the lake. Also thanks to David @ earmark for suggesting this amp
Old     (bushtree)      Join Date: Jul 2005       12-28-2012, 7:54 PM Reply
I am running the same setup on my boat. With the boat on the trailer, if i stand 70-100ft back the speakers sound incredible. Truly amazing. However, when I am actually on the water wakeboarding so much of that impressiveness seems to be lost... I can hear the music, but its almost as if all the mid-bass is drown out by my boat exhaust / wind noise.. Anyone else have similar experiences?
I think my boat exhaust is way too loud
Old     (durty_curt)      Join Date: Apr 2008       12-28-2012, 10:12 PM Reply
I still need to fine tune my Rev 10s on my Bu. Sounds really clear but its missing the mid bass..
Old     (xstarrider)      Join Date: Jun 2007       12-29-2012, 4:38 AM Reply
If you ask me the Rev 10's and 8's won't blow u away or be worth an upgrade if you only want tunes at the end of the line. The old pro series sound just as good. The Rev series however will blow any other HLCD away in the near field while Surfing, chilling or partying. They are absolutely amazing near the boat. Especially compared to my old pro 80's. again tho at the end if the rope I don't notice any difference.
Just my 02
Old     (shawndoggy)      Join Date: Nov 2009       12-29-2012, 8:00 AM Reply
^^^^^ this.
Old     (Jake)      Join Date: Nov 2012       12-29-2012, 8:02 AM Reply
Thats exactly what im using them for ..party cove and chillin around the boat..
Old     (h20king)      Join Date: Dec 2009       12-29-2012, 9:03 AM Reply
A fresh air exhaust or the Malibu silent rider turn down baffled exhaust tips are the best stereo upgrade for the money. It is absolutely amazing how much more sound you get when you turn down the volume of the boat. I went with the Malibu tips they are not as quiet as the FAE but still a huge improvement. If you don't have a wedge or a switchblade the FAE is the way to go.
Old     (xstarrider)      Join Date: Jun 2007       12-29-2012, 1:39 PM Reply
And I run mine with an FAE
Old     (CobraRob)      Join Date: Aug 2010       12-29-2012, 5:24 PM Reply
Running a pair of Rev410s off 2 of those amps.. KILLER sound.
Old     (gti2lo)      Join Date: Nov 2005       12-29-2012, 5:40 PM Reply
Harold, you got the turn down tips from Bakes?
Old     (durty_curt)      Join Date: Apr 2008       12-29-2012, 6:23 PM Reply
H20 King, how hard was it to install those turned down baffles?
Old     (h20king)      Join Date: Dec 2009       12-29-2012, 6:58 PM Reply
Yeah guys I got the turn downs from Bakes. The install was not bad the hardest part was getting the old ones off. The turn downs are only a three screw mount so you have to drill some new holes for the screws but not a big deal as the flange covers the old ones. All and all it was an easy project and money well spent.
Old     (Truekaotik)      Join Date: Jun 2012       12-30-2012, 6:53 AM Reply
DC,
Where is your hi pass crossover set at for the Rev10's? This will be your mid issue...
Old     (zacharoo)      Join Date: Nov 2005       12-30-2012, 4:36 PM Reply
@cobrarob...I wanted to ask you more about the HD750/1 x2 for your Rev410s. How does a mono amp work with 2 speakers per pod? An internal crossover?
Old     (chpthril)      Join Date: Oct 2007       12-30-2012, 5:01 PM Reply
Zach,
The JL 700/1 is a full-range amp much like a 2 chnl stereo or 4 chnl amp is. It does 750W rms into either a 2 or 4 ohm load, so its works well for a pair of high power HLCD's or a single REV-410.
Old     (CobraRob)      Join Date: Aug 2010       12-30-2012, 6:59 PM Reply
As stated it's a full range amp. The REV410s have the cross over built in. I have 2 amps 1 for each 410. As simple as connecting + to + and - to - You can then set the crossovers and gains on the amp.
Old     (david_e_m)      Join Date: Jul 2008       12-30-2012, 7:23 PM Reply
Although the HD750/1 is fullrange it has both a high and lowpass electronic crossover. And like any amplifier (2-channel or otherwise) you would run highpass when driving a tower speaker.
David
Earmark Marine
Old     (Truekaotik)      Join Date: Jun 2012       12-31-2012, 10:08 AM Reply
Ill say it easier.... Each 410 pod, even though it has 2 speakers and a horn, has 1 +/- 4 ohm terminal on the outside, Thats what matters.. The mono amp is stable from 1.5 to 4 ohms. Running two 410's parrallel, will put a 2 ohm load on the mono 750.1, giving each 410 pod 375 watts... And as stated this mono block is full range with a hipass and a low pass crossover setup... Most mono blocks are strictly sub (lowpass) amps, so make sure to do your homework when looking at mono blocks...
Old     (zacharoo)      Join Date: Nov 2005       01-01-2013, 1:11 PM Reply
That was an excellent description Truekaotik...Thank you all for the insight!
Old     (Houstonshark)      Join Date: Jan 2011       01-01-2013, 6:17 PM Reply
FYI, I have 4 MHD750/1's for sale in the classifieds section.
Old     (murphy_smith)      Join Date: Dec 2005       01-01-2013, 6:48 PM Reply
Sent you a PM about your amps
