Old     (hillbilly)      Join Date: Aug 2002       12-14-2012, 6:23 PM Reply
Boat just got a service done......Idles fine, But bogs down /dies under a load.
No codes come up on the computer according to the tech?
Anything I should look for or try?
Thanks.....
Old     (wakebordr11)      Join Date: May 2001       12-14-2012, 6:48 PM Reply
How did it run before the service?
Bad gas?
Vacuum line leak?
Fuel filter plugged or bad? Fuel lines? Pump?
Old     (mark197)      Join Date: Dec 2009       12-14-2012, 7:35 PM Reply
I had the same problem with mine after i was screwing around with the blower I found it to be a loose wire on the fuel pump. It would make a connection at idle then as the engine would vibrate the connection would fail and starve it of fuel.
Old     (hillbilly)      Join Date: Aug 2002       12-14-2012, 8:50 PM Reply
Thanks for the tips....Someone else is was using the boat and I was getting things 2nd hand.....I guess it was condensation/water buildup in the fuel they think.
I guess they idled it for about 10 min and a few backfires and it cleaned up.....Guess I should put a new cap/rotor and fuel filter on.
Old     (BrettHowell)      Join Date: May 2012       12-16-2012, 6:52 PM Reply
Did you accidentally leave moomba cruise on? It will behave funny if you turned the boat off and on with it still set.
Old     (hillbilly)      Join Date: Aug 2002       12-16-2012, 8:12 PM Reply
I forgot about the cruise issue.....
