Old     (Rockinrhino)      Join Date: Nov 2012       12-04-2012, 9:05 PM Reply
Would like to upgrade to a wakeboard prop but did't now if they made one for my 1993 Four Winns 190 Horizon. It has a 5.8l OMC Corbra out drive. Any Suggestions?
Old     (codykauz)      Join Date: Jul 2007       12-04-2012, 9:06 PM Reply
Hey, why don't you get back to work?!
Old     (spencerwm)      Join Date: Feb 2009       12-04-2012, 9:29 PM Reply
You need to lower the pitch. You are probably in the low 20's. Maybe look at something with between a 17 and 19 pitch depending on your gear reduction. Call JT and Nettle props. He will get you squared away.
Old     (Rockinrhino)      Join Date: Nov 2012       12-04-2012, 9:32 PM Reply
Right back at ya
Old     (chpthril)      Join Date: Oct 2007       12-05-2012, 6:08 AM Reply
Im guessing you are running some ballast now? Knowing what you have currently, makes it easier to make a suggestion. If you have a 3 blade, I would consider going to a 4 blade. This will offer more surface area which equals better bite and less slip and cavitation. Going down in pitch will help restore some hole-shot.
Old     (Rockinrhino)      Join Date: Nov 2012       12-05-2012, 9:11 AM Reply
Thanks for the info I'll Give JT a Call. Currently running stock 3 blade 14 1/4 x 21.
