Old    GD (diamonddad)      Join Date: Mar 2010       10-30-2012, 11:48 AM Reply
While my boat sleeps through most of the winter, I would like to apply a battery tender to maintain the batteries. Would any of you have a recommendation for a battery tender? I have 110 power available on my dock/hoist. Thanks.
Old    Johnny (guma)      Join Date: Sep 2009       10-30-2012, 12:07 PM Reply
I have a ProMariner ProSport 20 in our Ski boat and in my fishing boat. Love 'em!
Old    Russ Constable (Midnightv10)      Join Date: Feb 2012       10-30-2012, 12:15 PM Reply
+1
Old    GD (diamonddad)      Join Date: Mar 2010       10-30-2012, 12:25 PM Reply
Hmm. Thanks, but I was hoping for something smaller that was just a trickle charger. Would I install that on my boat or on my dock?
Old    "G" (grant_west)      Join Date: Jun 2005       10-30-2012, 12:26 PM Reply
Battery Tender is a Brand name
http://batterytender.com/
They work great, 2 Kinds of Battery chargers, The kind you mount in your boat, like The the ProMariner ProSport 20 talked about above, and the Battery tender you talked about that is made to sit in and around and then you unplug it and go on your way. They are cheaper and work well. Depending on what kind of batterys you have, Example im not sure the Battery tender is a SMART charger that has difrent program cycles for diffrent types of batterys.
If you have a traditional Wet/cell battery a battery tender will do the trick. If you have AGM batterys like a Optima I would go for a more expencieve smart charger
Old    GD (diamonddad)      Join Date: Mar 2010       10-30-2012, 12:58 PM Reply
Thanks Grant. Since I want to simply keep my fully charged batteries healthy while the boat sits for a month or two between outings, I am thinking the Battery Tender JR will do the job. Yes, I have standard lead acid batteries but I have a pair of them. Any advice on how to maintain the pair of batteries? Can I wire the tender to the perko and have the perko set to "both" to have both batteries tended?
Old    "G" (grant_west)      Join Date: Jun 2005       10-30-2012, 2:15 PM Reply
Dane yes if you directley to the battery's the battery tender comes with a quick disconnect you can buy Battey tenders that will charge more than one battery at a time. If you have anything else that could use a Battey tender u can get more quick disconnects and use it for other battery's while ur boat is in use all summer
Old    Tim (srock)      Join Date: Mar 2002       10-31-2012, 12:08 PM Reply
Grant your response may be confusing to us non-electrical experts.
One "Smart" battery tender cannot charge 2 batteries at once while the perko is set on "both". It needs to be a 2 bank charger and wired to each battery or you need to switch the perko to either battery 1 or battery 2. The exception may be with some sort of combiner isolator...???
Old    James Hosman (get_sum)      Join Date: Jun 2012       10-31-2012, 3:34 PM Reply
I just bought two of these. I've used them in the past without issue. http://www.harborfreight.com/automat...ger-42292.html
Old    "G" (grant_west)      Join Date: Jun 2005       10-31-2012, 4:05 PM Reply
Tim I would not hook a bat charger to a Perko switch I would run the Charge leads to each battery. But your correct on a single bank charge with a Perko.
Thanks for clearing that up.
Old    GD (diamonddad)      Join Date: Mar 2010       11-01-2012, 2:54 PM Reply
Guys, it looks like a single battery tender can charge two batteries in parallel without issue:
http://batterytender.com/resources/c...rs.htm#answer9
Old    Anthonyv911 (tonyv420)      Join Date: Jul 2007       11-02-2012, 7:59 AM Reply
I usually pull my battery out for storage, which charger should I put on it while it sits in my back room? I have a Optima blue top
Old    DTB (DatTexasBoy)      Join Date: Aug 2012       11-02-2012, 8:09 AM Reply
This has tons of info and pics. Good luck
http://www.wakeworld.com/forum/showthread.php?t=795665
Old    Tim (srock)      Join Date: Mar 2002       11-02-2012, 8:28 AM Reply
That is Not what I would do. Your batteries begin to equalize their potential when in parallel. (drain into the "lower" battery).
Don't just look at the picture. If you don't understand the paragraphs below the picture you don't understand why this is not optimal.
Old    Dave (wakebrdr94)      Join Date: Jul 2010       11-02-2012, 2:59 PM Reply
I bought 2 of these from ctek, they work awsome
http://smartercharger.com/products/b...multi-us-3300/
Old    GD (diamonddad)      Join Date: Mar 2010       11-03-2012, 1:09 AM Reply
Richard?
From the old thread pointed to by Rance, I think I like this guys post...
> i use a cheap walmart trickle charger with duel batteries switched to ALL have for many years never a problem
Old    Tim (srock)      Join Date: Mar 2002       11-05-2012, 9:46 AM Reply
^^Richard Hangslow that is... No I wasn't trying to be one but I understand why it appears that way.
I powered through all the Tender articles as an electrical layperson after dealing with a number of differing battery issues and an explosion but cannot provide a more simplified explanation. I was merely expression caution in my comment.
I do know that the picture will charge but it is not nearly as optimal for extending the life of 2 batteries as a fully independent 2 bank system.
Where's Dave?
