Old    Joel Schrader (extremewake)      Join Date: May 2011       09-26-2012, 10:38 PM Reply
Any body have any tips on changing the transmission fluid on a v-drive? I have read that there is supposed to be a drain plug underneath but I couldn't find anything. I'd rather not pump it out; but if that is the only way, obviously I'll have too. Any tips, tricks, pointers,or things to be careful of would be great!!
Old    Troy (liveoz)      Join Date: May 2002       09-26-2012, 10:58 PM Reply
Just passing on what I have heard. Pump out with a turkey baster, replace same amount as pumped out.
Old    Delta Force (wakebordr11)      Join Date: May 2001       09-27-2012, 5:54 AM Reply
Way easier to pump it out I imagine, and cleaner. No v-drive here but we pump out our direct drive. Speaking of which, if you have a transmission and a v-drive gear box, don't forget to do both with the mfr's recommended fluids
Old    Jacob Downey (jsmilez321)      Join Date: Sep 2011       09-27-2012, 7:12 AM Reply
I have yet to change my Vdrive and transmission oil, but i will do it next year before the season. I would highly suggest a Pella Pump. I got mine from skidim.com and made changing my oil a breeze. I just bought my first Vdrive boat so a little anxious about getting in there and changing all those fluids, but the pella pump made it very easy to change the oil!!!
Old    Skippabcool (skippabcool)      Join Date: Mar 2011       09-27-2012, 3:28 PM Reply
I change mine every year.
I started with this simple one:
http://www.harborfreight.com/multi-u...ump-66418.html
Then I got one of these:
http://www.westmarine.com/webapp/wcs...2#.UGTEyI1lSRg
Old    Joel Schrader (extremewake)      Join Date: May 2011       10-05-2012, 8:55 AM Reply
Thanks everyone for your tips!!
Anyone know what type of oil/fluid to put in the gearbox on the other side of the transmission?
Old    Jay T. (wakebrdjay)      Join Date: Apr 2008       10-05-2012, 12:44 PM Reply
If you have a Walter v-drive it takes SAE30 non detergent.
