Old     (trennaa)      Join Date: Oct 2012       10-24-2012, 1:36 AM Reply
I am looking at installing Wetsounds XS-650 in my 2006 Supra launch 21V but I am concerned they don't fit in the main lounge area above the cup holders due to the depth of the speaker, the XS-65 will as they 1/2 inch smaller but I just don't think the XS-650 will? I even cut a cardboard template out and it just hits the side of the boat from the inside.
Old     (chpthril)      Join Date: Oct 2007       10-24-2012, 4:36 AM Reply
If this is in an existing speaker hole, they run a straightedge across the hole and measure thr depth from the deck to the the hull. If you do not have enough depth, then you have a couple of choices: Go with the 65 series, do acrylic LED rings behind your speakers for some added bling, or go with a white (or deck colored) HDPE ring that will space the speaker out enough to clear.
Old     (david_e_m)      Join Date: Jul 2008       10-24-2012, 6:34 AM Reply
Spacing the speakers out can get a little tedious at the rear of the cockpit coaming pockets because a portion of the grill may be behind the coaming panel with limited depth on the face side. Oftentimes the grill can be modified a bit up and behind the panel where is does not show. However, this can be a problem with a component/coaxial where the grill is permanently integrated. So add this ingredient into the calculation.
Also, the protective boot around the XS-650 magnet can be modified to reduce the depth, whether or not that's enough to make up the difference I cannot say at this point.
David
Earmark Marine
Old     (trennaa)      Join Date: Oct 2012       10-24-2012, 11:32 AM Reply
Thanks for that
David how much is the thickness of the protective boot
Of the magnet
Old     (david_e_m)      Join Date: Jul 2008       10-24-2012, 11:46 AM Reply
I do not know the exact thickness and I'd rather not shoot from the hip. But I would email Wetsounds to find out the accurate number. And look over your boat a little closer as TigeMike's idea may be all that is required. Wetsounds has the light ring dimensions too.
David
Earmark Marine
Old     (jdb11386)      Join Date: Sep 2011       10-24-2012, 5:35 PM Reply
the led rings wetsounds offers might get you where you need to be. they will reduce the depth by a good 1/2 in.
Sent from my SCH-R530U using Tapatalk 2
