you may be pulling to hard to your back hip to get the scarecrow around...doing so would advance you on the boat, causing slack. Try this..edge out...make sure the load is already in your back hand. intiate a straight approach towards the wake with steady lean on the rope/back hand when you approach. shift weight to your front foot and flatten out up the ramp of the wake..wait...wait for the pop and then roll it over..the line tension will be there and it will help you complete the trick.
