Old    Max T. (airbeast)      Join Date: Oct 2009       09-05-2012, 11:56 PM Reply
I'm looking for a mechanical stargazer upgrade and multiline gauge.
I've had about enough of the paddlewheel perfect pass. My girlfriend and several people ride at slower speeds. Right at the point where the boat wants to fall off plane. There is some change in waterflow over the hull and the paddlewheel speed becomes eroneous and messes up the perfect pass. I basically have to drive them by hand. It has trouble holding well for me at times as well. Slows down and speeds up too much during turns in double ups.
Does anyone know of a better deal than straight through perfect pass?
Thanks.
Old    Tom (boardjnky4)      Join Date: Dec 2011       09-06-2012, 6:06 AM Reply
http://www.nauticlaugic.com/nl4-pp%20packages.html
There was a thread on here a little while back, and the consensus seemed to be that this works equally as well as the stargazer add-on for half the price.
Old    Max T. (airbeast)      Join Date: Oct 2009       09-07-2012, 1:07 PM Reply
Thanks for telling me about that. Ordered from them. $250 is much better than $700
Old    Shredtastic (seth)      Join Date: Sep 2002       09-07-2012, 1:17 PM Reply
Yep, it works awesome. Ive been running the Nautic Logic all summer.
Old    Tom (boardjnky4)      Join Date: Dec 2011       09-07-2012, 1:21 PM Reply
Glad to help
Old    Max T. (airbeast)      Join Date: Oct 2009       09-14-2012, 5:29 PM Reply
Best $250 spent. Solved all my issues. I highly recommend! Only thing is it needs a really clean power supply. I had an electromagnetic fuel pump on the same circuit and it jitters the voltage enough to where that nautic laugic box drops out. A clean supply voltage solved that problem.
Old    Fred (olmoomba)      Join Date: Apr 2010       09-18-2012, 3:37 PM Reply
2 years with nautic logic. holds dead on, my paddlewheel still works my speedo on my dash, so I can compensate when on a river. my only complaint is the connection gets loose on my set up at the input to the module. I probably just need to add some conductive grease to help with the contacts.
