Old    Tim (srock)      Join Date: Mar 2002       09-11-2012, 6:10 AM Reply
If I am correct the Ronix bindings can be molded to your feet by a special "cooker" from the manufacturer. What do you do if you buy the boots online to form them?
Old    Tommy (Readyaimfire)      Join Date: Jun 2012       09-11-2012, 6:41 AM Reply
Use a blowdryer. Heat em up real hot. Make sure u wear socks so u dont burn the **** outta your feet!
Old    CORY MITCHELL (stang_killa_ss)      Join Date: Jan 2010       09-11-2012, 7:22 AM Reply
no one does that.
just put them on. ronix has the best foot fit in the industry.
the more you wear them, they will mold even better to your feet.
bolt them up and go ride.
Old    Mike Vasquez (mikeakatex5)      Join Date: Jun 2009       09-11-2012, 7:37 AM Reply
^+1 They should feel pretty good right out of the box, and just keep getting better the more you're in them
Sent from my ADR6300 using Tapatalk 2
Old    TJ (Houstonshark)      Join Date: Jan 2011       09-11-2012, 10:22 AM Reply
I've never done it but I think I remember hearing that you can drop them into a bucket of really hot water and then slip your foot in, lace it up and wear them for a few.
Old    August (augie_09)      Join Date: Mar 2011       09-11-2012, 10:59 AM Reply
if you really want, guess you could go into a snowboard shop and use theirs.
Old    Bryce Stevens (SS_Hooke102)      Join Date: Sep 2011       09-11-2012, 11:08 AM Reply
My ronix dealer has the heater. Most of them do from my understanding. i've also heard of using the oven... sounds pretty damn sketch to me.
Old    Jamie Corvin (Bumpass1)      Join Date: Oct 2010       09-11-2012, 12:50 PM Reply
Hot water from the shower for 10 minutes then strap the on for 5 minutes and stand there.
Old    Tim (srock)      Join Date: Mar 2002       09-13-2012, 9:52 AM Reply
Do I do that naked or with board shorts on?
Thanks for all the reply's.
Old    Cj (cj1)      Join Date: Sep 2012       09-13-2012, 10:08 AM Reply
Definitely dont get the heat molded unless your only riding in really cold water. Getting them heat molded will make them wear quicker. I got mine molded in a cooker and they actually burnt. I was told it was a defective liner and a manufacture defect so i got new boots for free : )
Old    David (Luker)      Join Date: Feb 2010       09-13-2012, 11:27 AM Reply
https://vimeo.com/17627146
Old    Jack (miljack)      Join Date: Feb 2006       09-13-2012, 3:02 PM Reply
I just molded mine the other night using a blow dryer. Left it on for 3 min and then stood in them for 10-15 min.
Rode in them after and noticed better support of my arch, and my feet didn't cramp when I had them cranked tight with the laces.
IMHO wished I would have done it sooner.
Old    TJ (Houstonshark)      Join Date: Jan 2011       09-13-2012, 3:22 PM Reply
I think this video is a little more appropriate since he asked about Ronix bindings:
http://www.youtube.com/watch?v=-P8paUSjwik
Old    Jamie Corvin (Bumpass1)      Join Date: Oct 2010       09-13-2012, 5:50 PM Reply
Safety first, please wear your vest.
Old    Jo Shmoe (joeshmoe)      Join Date: Jan 2003       09-13-2012, 8:41 PM Reply
and what temperature does the hair dryer reach? hair dryer works great on wet hair but is not good for dry hair. I would believe the heaters at the ski shop have a controlled heat to get a precise temperature to heat mold the boot. Do not go over 130 degrees for your boots, it is very easy to get water at 130 dgr, push them down under the water(too hot to push down with hand) for 10 min, put on your feet(with socks), do Not tighten, cool and you are good to go!
Old    Tim (srock)      Join Date: Mar 2002       09-14-2012, 10:34 AM Reply
...a helmet would be a more appropriate safety device. I'm to large to fit down the drain.
Old    Tim (srock)      Join Date: Mar 2002       09-14-2012, 10:38 AM Reply
I think I will hold off and ride them a little. If they don't feel right, like in my arches, then I'll try the hair dryer....naked of course with vest and helmet on.
