Old     (stang_killa_ss)      Join Date: Jan 2010       06-30-2012, 11:55 AM Reply
pump finally gave up the ghost...
jabsco 18220-7127 from '11 moomba LSV
i called the stealership and they do have one for $290 + tax + the 3 hours on the road to get it.(they also confermed the part number)
well i google that number and google nor yahoo could find ONE SINGLE hit on that number
but there are a million hits for the 18220-1127 which wakemakers sells as well. $209
http://www.wakemakers.com/jabsco-bal...oard-pump.html
it looks 99% identical but obviously the part number is wrong. i wonder what the difference is? and why cant google find a single hit on my part number?
i wonder if the difference is the plug thats on mine for moomba? (1127 has no plug) or possibly the impeller type although both come with the nice green impellers.
any one have any knowledge with this?
Old     (chpthril)      Join Date: Oct 2007       06-30-2012, 12:13 PM Reply
Just curious, does your 2011 not have warranty that covers this? I also find it odd that a year old ballast pump motor would fail. Was it mounted with motor down/head up?
Yes, the 1811-1127 should work. Is yours used as a reversible, or does it just fill the sacs? if you only need one to pump one way, Jabsco makes a 6+ GPH pump that runs about $150.00.
Old     (stang_killa_ss)      Join Date: Jan 2010       06-30-2012, 12:17 PM Reply
it did have warantee. in february. lol the only thing that failed on my boat during the 1 year warantee was a $3 stereo cable haha.
yeah i could get it to come on sorta by manually hooking up 12v directly to the wires, but the shaft waddled like crazy, and it grunted and growled terribly, and sound was wavy, ie rpms changeing alot. then it would just lock up again and short out when you would add 12v. now its locked up good. i cant even spin the shaft with pliers anymore.
yes it was mounted vertically. impeller on top. yes mine is reversable.
i would just really like to find out more about the 7127. its just crazy that theres not one single trace of this pump on the internet.....
Old     (chpthril)      Join Date: Oct 2007       06-30-2012, 12:22 PM Reply
Id bet if you pull it apart, you will find that water seeped into the motor and killed the bearing. Get the 1127 and mount it motor up.
Old     (stang_killa_ss)      Join Date: Jan 2010       06-30-2012, 12:33 PM Reply
yeah i already dismantled it and came to the same conclusion.
thanks for the orientation idea. thats a good point.
just wish i could find some kind of actual info on my 7127
Old     (chpthril)      Join Date: Oct 2007       06-30-2012, 12:53 PM Reply
Call Jabsco on Monday and ask them. They have a east coast office and a west coast office. Im sure they can tell you exactly what the diff is.
www.xylemflowcontrol.com is who the Jabsco name is under.
Old     (volzalum)      Join Date: May 2009       07-01-2012, 7:42 AM Reply
I talked to jabsco a few years ago when I was adding pumps to my system and they told me the ballast puppies were all the same with different numbers related to whether they were providing to retail or boat manufacturers. Most likely the the one in your boat was just branded (numbered) for your boat manufacturer.
Old     (stang_killa_ss)      Join Date: Jan 2010       07-01-2012, 7:44 AM Reply
that was my guess too. thanks for confermation. explains why google cant find a single thing on my part #
Old     (spencerwm)      Join Date: Feb 2009       07-01-2012, 9:01 PM Reply
Originally Posted by stang_killa_ss View Post
that was my guess too. thanks for confirmation. explains why google cant find a single thing on my part #
That is correct. Same pump with an OEM part number. To my knowledge the only Manufacturer that does run a little different pump is Correct Craft. They run the Commercial Water Puppy. Basically the same thing as the Jabsco Ballast Puppy.
