Old    Hydrodynetahoe            06-21-2012, 12:15 AM Reply
hi there you guys. I'm looking into buying a 2004 Toyota sequoia do you guys think it could tow a 1996 Hydrodyne Grand Sport up to Lake Tahoe.
Old    Cody (loudontn)      Join Date: Feb 2005       06-21-2012, 4:48 AM Reply
I see you're in Santa Clara, which is about a three and a half hour drive to Lake Tahoe (according to Google maps). I'm not sure how much the Hydrodyne weighs because I'm not familiar with that boat but if I remember correctly it's a ~21ft direct drive, I imagine the Sequoia would be perfect for that tow. I tow my 24 Launch with an 03 Sequoia and though it sags the back slightly I probably wouldn't have a problem doing the same tow (though I'd be shelling out loads for gas).
Old    Tony Medaglia (h2ohangtime)      Join Date: Aug 2002       06-21-2012, 5:25 AM Reply
Make sure it has a transmission in good working order, because you'll likely blow through it doing that drive up 80 or 50 on a regular basis.
Old    J Murez (jmurez)      Join Date: Jan 2009       06-21-2012, 8:45 AM Reply
Unless you have a specific 2004 you are looking at, try to go with 2005-2007. 2005 got a little face lift (you can tell by the tail lights) and was the first year of the 5 spd. transmission (2004 below is 4 spd.). Also, I know my 2005 was listed at 273 hp, which was a little bump from prior years (I think 240 hp). Only major maintenance to watch for is a timing belt @ 100k.
Old    Todd (antoddio)      Join Date: Dec 2006       06-21-2012, 9:11 AM Reply
Post the weight of your rig for a more accurate answer.
You might consider getting a 4 runner of the same year- has a 1000lb greater tow rating. If you don't need the room.
Old    Hydrodynetahoe            06-21-2012, 11:25 AM Reply
the boat weighs 2550 pounds plus i live in Santa Rosa, ca
Old    Hydrodynetahoe            06-21-2012, 11:31 AM Reply
oh and do you guys think it could tow a 2000 or 2001 mastercraft x-star up to lake tahoe.
Old    Hydrodynetahoe            06-21-2012, 11:33 AM Reply
plus do you guys think it could tow a 2000 or a 2001 mastercraft x-star up to lake tahoe
Old    Brett Yates (polarbill)      Join Date: Jun 2003       06-21-2012, 11:43 AM Reply
I think a V6 4runner or tacoma would tow your boat or the 2000-2001 xstar up to tahoe. It just might be real slow going. The Xstar probably only weighs 500-600 more then the hydrodyne. I think a sequoia would be fine as long as you take it a little easy and drop it into 3rd gear or whatever up hills. May look at a transmission cooler though.
