Old    Stephen (sk4910)      Join Date: Jul 2011       06-08-2012, 7:45 AM Reply
I have a 2005 Sanger V210 and my ignition switch is starting to go out. What kind of switch do I need to replace it? Can anyone please point me in the righ direction? I keep finding these push to choke ignition switches but I know that is not what I need.
Thanks in advance!
Stephen
Old    Jman (jmanolinsky)      Join Date: Dec 2005       06-11-2012, 12:17 PM Reply
What are your symptoms? I ask because I thought my ignition switch was going bad because sometimes when I turned the key, nothing would happen. I could always release and turn again and it would turn over, but it gradually got worse. After talking with the parts guy at the shop, he convinced me that it wasn’t the ignition switch, but a relay or something that is located under a cover on the top of the motor at the back. I replaced that and my problem went away. This was on an Indmar.
Jman
Old    Greg McNeill (greg2)      Join Date: May 2002       06-11-2012, 9:20 PM Reply
J man, out of curiousity where was the relay...just in case I ever encounter the same problem??
Old    Jman (jmanolinsky)      Join Date: Dec 2005       06-14-2012, 10:47 AM Reply
If I remember correctly, it is under a black plastic cover mounted to the back of the head on the driver's side.
